S/C 5.0 Plugs?
  • SicLinc98
    Sic One
    • Sep 2005
    • 3027
    S/C 5.0 Plugs?
    Ok so I have my motor ripped apart and figure ill change the plugs since the SC is off. I have a 93 5.0 all stock with a Vortech running 9lbs(only go to 5-6 though) What plugs should I get? Part number would be great too. I dont know whats in there now as I have not pulled them but im not sure if there right. Also double platnum or any of those work better?
    Dan
  • sc0tty8
    Raised by wolves
    • 4134
    Prob a copper plug is what you will want.
    No sig for you.
      autolite 24s are what I run. I am all stock except for exhaust and an intake
      • SicLinc98
        Sic One
        • Sep 2005
        • 3027
        ill try those then. Thanks
          forgot to mention incase you dont already know, that is a 1 heat range cooler plug.
          • SicLinc98
            Sic One
            • Sep 2005
            • 3027
            Ok well TRDon I went with what you told me. Good news is when I pulled my plugs they looked real good. So what that means is time to see what this car has I did find out why theres a wrench slot on the spark plug socket. Long Tubes FTL.
            • Turbo302
              • 1528
              You can go even one more step colder to Autolite 23's. They are a little harder to find, but are two steps colder than stock. Thats what I run with an MSD and .030-.035 gap.
              Tim
              1988 5.0 Notchback
              • Meegs
                AA for Mustangs
                • 3062
                ever though about doing a 23 in the #7 cyl?
                93 Teal Cobra #2531
                Turbo Cobra MAFIA
                1 of 452
