Hardened oil pump drive shaft?
  • 00svtcontour
    • 929
    I need some feedback. Is it worth the time to buy the hardened one, or is the stock one just fine?? I am putting a motor together for my t top and not sure if i should buy a new oil pump and driveshaft, or just buy a oil pump and a hardened shaft, or just reuse both. The motor ran awesome about 3 years ago, and has been sitting on a engine stand since. It will be going in my car, with not alot of mods, but some: long tube headers, underdrive pulleys, 65m tb, a/c and smog delete, adj. fuel pressure regulator, pretty much stock! Let me know what you guys think. Thank you.
    Matt
    definitely buy a hardened one.
    they are cheap insurance, i think they're only 30 bucks or so.
    i'd probably also put a new pump in it also, they're cheap too and oil is important.
    • 00svtcontour
      • 929
      $18.95. Oil pump too??
        i would.
        • Turbo302
          • 1528
          Get hard shaft!!!
          1988 5.0 Notchback
          • 00svtcontour
            • 929
            Anyone else have anything to add that might actually help??
            • Roast'em
              has posted this
              • 5496
              I went with an ARP shaft and melling pump. For whatever reason, there were clearance issues with the distributor. So maybe don't go with that combo...
