Ahhh... The luck i have!
    Sooo... i go to bleed the brakes tonight... Doing all 4 because it pulls to the right like a bitch on crack, with a black eye.
    Any how....
    Low and behold... I find a broken spring in the front Drivers side.... The Rear Passenger Side ( this one is just hanging there, waiting to puncture my tire!, and a broken Strut on the rear Drivers side.
    To make things even better, i have some play in the front end on the passenger side axle/CV what ever... its fing Wrong wheel drive.... So im not sure if the cv is junk going into the tranny, or if my Diff is missing a few teeth....
    FUN STUFF!
    Wow, thats must've been a little scary driving that
      When???
      Ill be driving it again tomorrow....
      and Wednesday....
      Wont be able to remove springs and struts till wednesday night looks like im gonna corner easy.. for a couple of days...
      • Chrm97PI
        268ponies with more onthe way
        • 3413
        just drive it like you knew nothing was wrong
          120 down 94 is the plan...
            why bleed the brakes if you have a pull? Maybe I am wrong but I have never heard of this before. Second, your driving it with broken springs and struts as well as a fucked up axle? you have a death wish, please dont drive on the same roads I do.
              • D3thM3tal
                IT Pro / Mechanic
                • 3665
                Wow, there is devine proof that whatever Joe drives, not only immediatly depreciates in value, but is soon to break/wear down all driveline and driveline related components.
                LOL, at least you have a parts car.... sure getting your use outa that thing..
                When your spider gears go, I guess I can help you with the trans...
                I bleed blue
                  Didn't you have a car with the engine held in place with tie-down straps/ratchet straps?
                  • Sleeper
                    Reasonable volume.
                    • Nov 2003
                    • 14888
                    turns out i dont have the shittiest beater on tcs.
                      No.. but close.
                      The 97 Cavalier...
                      the A arm Bushings were completly gone.. so the driver side a arm sat back a little bit.
                      Took a chain ratchet strap, ratcheted it forward, tied it off with wire. Drove it like that for 11 months.
                        Well since i didint have the tools to take care of it last night, and i am going to the twins game tonight, I will replace it all tomorrow.
                        I dont know how long theyve been broken, whats another 2 trips to and from work
                          No.. but close.
                          The 97 Cavalier...
                          LTD is a retard at explaining things.
                            just watch out with that axle. i had a honda one time, and the final drive in the tranny got excessive to the point that the cv axle would pop right out of the tranny going down the highway, i'd pop it back in on the roadside and go 10 miles and do it all over again. but there was probably 1/2" of play. after about 5 times doing that in subzero i drove it to the junkyard and got $9 cash for it in scrap.
                              Don't we all know it?
                              Tell em the Lumina still runs good. Fixed 1 oil leak (Valve cover gasket... now timing chain cover leaks... Oh well)
                              Need to do a wheel bearing but may say f it...
                              Runs good otherwise.
