Need Help
  • players02GT
    • 356
    Need Help
    I went to take my car out of storage yesterday and it wouldn't start. The battery is fully charged and it turned over just fine, but it never tried to fire. I could hear the fuel pump running when I tried to start it. I had a program in the computer but I backed it out with my Predator and it still did not fire. I reinstalled the program and still nothing. I did the whole disconnnect the battery thing a couple times. When I read the error codes with the predator it just showed the code for the custom tune. When I tried to see what the VIN number was using the programmer it returned all F's. This occured with both the stock program and the predator program installed in the ECU. To me it sounds like my computer died. What do you guys think? If that is the case I am going to be pissed because I have already replace the ECU once and had to pay for it out of pocket because of having a chip on the ECU. What would cause a computer to go bad? Last time the car was driven wasn't even 3 months ago. I can't go back to my dealership and try to work them for anything either because American Ford is not in business anymore. Any suggestions?
    :vader:
  • Chrm97PI
    268ponies with more onthe way
    • 3413
    where your odometer is does it display the mileage or is it all dashes---..
    • players02GT
      • 356
      It acutally shows my mileage. The last time my computer died it showed ---- but that is not the case now.
      :vader:
      • Fosters
        Typical white person
        • 16014
        did you go through the built in diagnostics - hold trip reset button, turn key to on? any DTC codes thrown that way?
        • Chrm97PI
          • 3413
          prossibly on got something else going on other than the pcm
          • EFI Performance
            EFI is back!
            • Dec 2005
            • 636
            Theft light flashing with key on?
            • players02GT
              • 356
              Theft light is not flashing. I am not familar with how to get codes from the car without using the programmer. How do I go about doing that? And what am I looking for?
              :vader:
              • players02GT
                • 356
                The trip meter thing doesn't seem to show any error codes. The Predator indicated a code of P1000 which is OBD-II Monitor Testing Incomplete . Any suggestions?
                :vader:
                • Chrm97PI
                  • 3413
                  p1000 is nothing, but check under the hood and make sure there is no damage to any wires and that everything is plugged in, mice like cars that are stored for winter, it doesnt take long to chew some wires to keep that thing from running
                  • SmithEvo
                    Poppin' VTAK yo!
                    • Nov 2004
                    • 25468
                    checked fuel filter?
                    Not at the table, Carlos.
                    • ruthless351
                      LS What??
                      • 206
                      Is it sparking and or are the injectors firing?
                      Shawn
                      1993 Mustang GT
                      5.0 5-spd
                      • players02GT
                        • 356
                        I will definitely check these items. I could use some help though. Anyone free for a couple hours this weekend to help me trouble shoot?
                        :vader:
                          if you dont get it figured out by fri. send me a pm I will help you this weekend
                          • players02GT
                            • 356
                            Thank you Jon
                            I wanted to say thanks Jon for your help with the car. Took a little engineering and a BFH but the car started and it is running like a champ.
                            :vader:
                              What was the problem?
