oil pressure guage & coolant gauge issue...
  • lilstang5O
    • 9204
    Got to questions.
    #1 the oil pressure gauge don't work at all. The guy said oh its un hooked. After looking at the car today, it looks to be all hooked up and all, but just not working. I assume bad Oil sending unit?
    #2. The coolant gauge after having the car idle for a bit then went for a 5 min cruise, the coolant gauge was in the red. The factory ecltric fan looks like it wasn't turning on. Thier is a zip tie holding the wireharness into the fan, maybe a bad harness or bad fan?
    Also all the fuses looked good.
    Ride:
  • Bryce'sStang
    • 1929
    if the fan is not turning it could be the connection at the fan(they have a tendency to melt) or the ccrm module(it is on the black overflow bracket)
    Under Construction....
      The fans have been known to fail if the recall from Ford has been performed
        see lilstang you should have never bought an sn95.
        to check the oil pressure sensor touch the connector to ground and have someone watch the gauge. if the gauge reads max pressure, replace the sending unit.
        • lilstang5O
          • 9204
          thanks guys will check her out tomarrow.
          MNstang, yeah I know but I've allways wanted a SN95 with the 5.0 but looks like once again the fox's out do then sn95's one of them will be sold this summer!
          Ride:
            Buying an Sn95 when you already had a fox and a very limited budget was an extremely bad choice. Not that I dont think theres anything wrong with them....... :/
            • KickAssFlash
              TCS AutoX Driver
              • 11568
              You bitches be hatin on the far superior 95.0s?
                bitch you don't know me
                • KickAssFlash
                  TCS AutoX Driver
                  • 11568
                  you will be beaten for your insolence
                    He will be beaten in a burlap bag
                    • Chrm97PI
                      268ponies with more onthe way
                      • 3413
                      Originally posted by lilstang5O View Post
                      Got to questions.
                      check to make sure your thermostat isnt stuck closed, that would cause over heating, and make sure your radiator is clean on the outside
                        • lilstang5O
                          • 9204
                          true. the radaitor looks great. He replaced it last summer. The thermostat im not sure on, but will put a new one no problem.
                          Ride:
                          • SicLinc98
                            Sic One
                            • Sep 2005
                            • 3027
                            Im guessing the harness is shot. Mine did the same thing and I replaced the TS and it still did it let it idle till hot the pulled the harness from side to side and it would turn on then id let go and it would shut off. you can try that and see if it will turn on.
                              I have a sn95 and a fox Have to say there is something about the fox, but I like driving my car better. It is way more civil
