In my 93 150..Pull the headlight switch and no headlights.....Once in a while it takes time and they will come on.....Problem started with the high low switch on the column.Click to high they would all go off.....Which one should i put in first......Also how to pull dash apart to get light switch out..
head lights no worky
i would say before you go shotguning parts at it to fix the problem, i would pull the dash apart and get at the headlight switch, if its similar to the ones that are in 94-04 stangs after time the plastic part which contains all the wires on the back of the switch will melt and cause issues, i had this issue on my 95 stang, whole back of the switch was melted, replaced the switch everything worked like brand new, just make sure you check out every angle before you drop 70 on a multifunction switch
Had the same problem on my 94 Mustang GT. I bought a repair harness for a 93 F-150 and soldered it in and everything worked fine after that. Didn't even have to replace the light switch.Originally posted by Chrm97PI View Posti would say before you go shotguning parts at it to fix the problem, i would pull the dash apart and get at the headlight switch, if its similar to the ones that are in 94-04 stangs after time the plastic part which contains all the wires on the back of the switch will melt and cause issues, i had this issue on my 95 stang, whole back of the switch was melted, replaced the switch everything worked like brand new, just make sure you check out every angle before you drop 70 on a multifunction switchLOOK HERE:Originally posted by Pony5.0but hey we have broken up 2 times in the past week and she keeps crawling back to me and she told me she would never crawl back to a guy and i am the only one. she tells me she loves me and everything!
Originally posted by NickYou ever make 150k per year? LOL, j/k we all know you're way too dumb to achieve this.
