Car trailer sizes for Mustang
  • usafracer
    • 237
    #16
    Take a look here. This is where I bought my 18' and love it.
    • Steve
      eMechanic
      • 5381
      #17
      Can you tell me how much you spent?
      • bad-speller
        • Feb 2004
        • 943
        #18
        Steve,
        If your going to go with the off name cheaper (pricewise, I am not making a judgement beyond that) make sure you check out what the trailer has for axles. Are they a common axle that parts are readily available for so if you have to fix it 500 miles away from home, you aren't dealing with something weird.
        I sell trailers, axles/brakes are one area companies can save alot of $$ when it comes to keeping the price low. For the traveling your going to do, a $2000 trailer is not a quality trailer from my experience.
        Brian
        2006 NASA American Iron Midwest Champion
        2005 NASA American Iron Midwest Champion.
        2010 Camaro SS (My New Racecar, coming soon)
        08 Corvette Z06
        09 BMW M3: Interlagos blue, SMG II
        00 Mustang Cobra R
        95 Mustang Cobra R (#23 NASA AI midwest)
        94 Mustang Cobra (#23 NASA AI midwest) SOLD
        09 BMW X3
        My braking point entering a corner is when I see the corner worker raising the yellow flag for me
        • Steve
          eMechanic
          • 5381
          #19
          Brian
          Do you have experience with H&H trailers? I really know nothing about trailers and want a quality 18 ft tandem axle trailer. I was planning on looking at H&H trailers because they seem to be sold nation wide and offer what I want. They have 18ft (overall length) trailers with a 2 ft BT for around $2200.
          When you say off brand, you lose me. I don't know what a brand name would be, except featherlite.
          Can you pm me a list of what you have available? I would like to give a friend business (if I can afford it) before anyone else.
          Steve
          • bad-speller
            • Feb 2004
            • 943
            #20
            Originally posted by 92MNstanger View Post
            Brian
            Do you have experience with H&H trailers? I really know nothing about trailers and want a quality 18 ft tandem axle trailer. I was planning on looking at H&H trailers because they seem to be sold nation wide and offer what I want. They have 18ft trailers with a 2 ft BT for around $2200.
            Steve
            I have seen them(the H&H) around, but have never looked at them very closely. BTW, I am not a big Featherlight fan either. lol
            Often the "cheap" trailers I see are trailers sitting on lots that are built by a local welding shop or a fabrication company. Just to give you an idea, the cheapest trailer that I sell is in the $2500-2700 range and I consider them marginal at best. They are fine for relatively local trips, but the long hauls we are usually doing is different.
            It gets pretty expensive to fix a tire, axle, or brakes when you are on the road. One question I would ask a place before buying a trailer is: do they have the bearings, brakes, and tires on hand at that specific time for the trailer you are looking at. If they don't and try to tell you "they can get them fast: or "you can get them anywhere" they are probly not real serious about the trailer business and you might want to do more research before buying.
            Sounds like others in here have experience with "other" trailers. If they have had good luck and are using them the same way as you will be, that is probly as good of a guarantee as your going to get.
            Have you done some searching on CC's or track sires like that? Like I mentioned in a earlier post, you will pat yourself on the back if you buy a trailer that has a low profile fender, or if it has a quick release fender that can easily be removed in order to open the door on the car once it is loaded. Remember to compensate for the possibly lower ride height that you might run on a track only type car.
            None of the trailers I have will clear a drivers door, there are better trailers for your type of use. I appreciate the thought though.
            Brian
            08 Corvette Z06
            00 Mustang Cobra R
            09 BMW X3
            • YouNeverSawMeHere
              TCS' Commodities Specialist
              • 9057
              #21
              I am looking at buying an open trailer in a coulpe weeks for hauling my fox mustang to Open Track Events. I do not know much about trailers/towing so I have a bunch to learn.
              Here's what I *think* (based on my reading so far) I need.
              1)16 or 18 ft tandem axle, prefer 16 if I can get away with it for cost/weight savings.
              2)Electric Brakes. On one or both axles? I thought I read that MN requires brakes on all wheels.
              3) Some type of pulling machine. I am leaning towards a mid/late nineties F150 with a 5.8 and a manual transmission. These are within my budget and can be had with less than 100,000 miles on them. I have looked at F250 diesels, but don't want to replace a tired (200,000 mile) E4OD.
              4) trailer brake controller, class 3 or 4 hitch.
              5) Things like tool boxes, leveling hitches, lights and winches can wait until I figure out the basics.
              Am I missing anything?
              Does this look like a good start?
              Is 16 feet enough bed?
              Thanks
              Late 90's 2wd LD250 with an I6 would do you great if you purchased and an Aluma(aluminum) trailer.
              Available on Amazon
              >>Click here<<
              • Steve
                eMechanic
                • 5381
                #22
                I took a look at CC.com and I saw a few used trailer ads and all other threads were about tying a car down (very informative) and adding accessories to your traile (ie tire racks and tool storage).
                I will have to look harder when I am at home, my lunch isn't long enough to look.
                What trailer spares do you carry?
                Wheels/tires, lugnuts, straps? Hubs?
                • YouNeverSawMeHere
                  • 9057
                  #23
                  ratcheting wheel straps... or T-hooks on chains with binders.
                  Available on Amazon
                  >>Click here<<
                  • Steve
                    eMechanic
                    • 5381
                    #24
                    Highly recommended on CC.com
                    • bad-speller
                      • Feb 2004
                      • 943
                      #25
                      Other than a spare tire, I don't carry anything. I take everything apart once or twice a year and go thru it all. Never had so much as a flat tire. (I replace the tires every three years)...................... I guess I should practice what I preach, huh? lol
                      Brian
                      08 Corvette Z06
                      00 Mustang Cobra R
                      09 BMW X3
                      • HTMtrSprt
                        • 488
                        #26
                        I have to kick in my 2c worth. I had open trailers and bought my first enclosed back in 1996. I would never go back to an open trailer again. The ease and safety of an enclosed far outweighs the fuel savings. It is nice to have interior lights, a winch and extra room for stuff you need at the track. You also don't get as dirty when you strap down a car in an enclosed. If it is raining it is really nice to be able to pull your car in and work on it. It also doubles as storage for your car and extra parts in the winter. A 20ft enclosed used or new is between 4000-15,000 depending how fancy you want to get. The aluminum trailers (featherlite) are awesome but they are more money. What is the price on the featherlite 20 without the truck???
                        Bart
                        • Steve
                          eMechanic
                          • 5381
                          #27
                          Thanks, Bart.
                          I have to start somewhere and don't have $4000 in my budget right now. I have to buy a truck yet. I may fix that this weekend.
                          Maybe I should just pay Barry to bring my car with him....
                          • ScotWithOne_t
                            OMGfast. Always.
                            • 5849
                            #28
                            No, you have to have a trailer so you can tow me home when I break down.
                            • Steve
                              eMechanic
                              • 5381
                              #29
                              Then you get to cram into my car!!
