AOD SHIFTER STUPIDITY
  • Wilbur
    I hate cars!!!
    • 509
    Anyone know of a way to change the shift pattern in this shifter? Want to know if there is a way to go from 1-2, 2-3, 3-od.
  • HARD ON RUBBER
    The Original 5.0
    • Jan 2006
    • 1157
    I agree. The aod shift pattern sucks. I was told the only way to change the pattern is new valve body. TCI or Lentech have them.
    1993 Mustang GT, Cobra intake, F cam, 42s, Pro-m 80, 70mm TB, AFR 165s, MAC shorties, MAC H-pipe, Flowmaster 50s, AEM wideband, 3.73s, Centerforce DF clutch, G-Force T5, NOVI 1000, TWEECER custom tune by EFI Performance www.EFIPERFORMANCE.net Dyno'ed at MAPerformance 435rwhp 420tq. True story.
    Vice Prez WCR
    • Racin Repair
      You wish!
      • Mar 2005
      • 2166
      You cannot change the pattern unless you buy a re-routed valve body that puts overdrive on a switch such as mentioned above.
      9.10@142 on DOTs thru the mufflers, back when I used to race...
      • PHRANQUY
        Grrrr...
        • 12166
        • roast'em89
          let the smoke roll
          • 275
          what do you mean i can go through all gears just fine
          you gotta pin it to win it
          • PHRANQUY
            Grrrr...
            • 12166
            You can manually shift it through each gear without doing the shifter dance?
            • sc0tty8
              Raised by wolves
              • Feb 2006
              • 4134
              You want a manual reverse valve body. I don't know if such a thing exists for an AOD, but, I would not recommend manually shifting a stock AOD, thats how I toasted OD in mine
              No sig for you.
              • 96zjlimited
                • 2092
                I can in my stupidduty.
                • sc0tty8
                  Raised by wolves
                  • Feb 2006
                  • 4134
                  I checked jegs, they have a manual valve body.
                  Summit has 4, none are reverse, or that they list...
                  TCI site should have more info, call them, the reverse pattern should be PRN 1-2-3
                  Lentech does have one, does not say if its a reverse pattern or not.
                  You also can't put OD on a switch, the AOD is not electronic
                  No sig for you.
                  • konastang5.0
                    Coyote Power
                    • 4317
                    Same here, i used to do the 1-d-1 shuffle with my old tranny but again toasted my OD band. Do not do this unless you have a valve body meant for it. It will quicly turn into a high expense in no time. I have the lentech valve body in my tranny and its shift patter is 1-2-3/4 (4 is electric OD switched). This solinoid stops the OD band from temporarily enaging when your manually shifting the car.
                    2015 Mustang GT
                    • CCr
                      The penis has spoken.
                      • 10966
                      How does it shift otherwise? I'm confused.
                      Originally posted by xjfish
                      • sc0tty8
                        Raised by wolves
                        • Feb 2006
                        • 4134
                        Really? They make the OD electronic then with the manual valve body? I know on a stock trans, as long as you don't put it in OD, you do not use OD, but, you need a moddided valve body to get 4th(OD).
                        Either way, the AOD is weaksauce. I toasted 1, then my bro put one into the car after I sold it to him and, it was a turd, you would lay on it, power band would hit, and, it would slip, it has a 5 speed now, so, no slippage
                        No sig for you.
                        • sc0tty8
                          Raised by wolves
                          • Feb 2006
                          • 4134
                          Autotragic shifts like an automagic...the reverse valve body is so you can shift it on your own, IE, when you move the shifter, it gets a new gear.
                          No sig for you.
                          • CCr
                            • 10966
                            so it's a manual automatic?
                            • sc0tty8
                              Raised by wolves
                              • Feb 2006
                              • 4134
                              Yeah. No clutch. Load up the TC.
                              No sig for you.
