rough shake
  • SicLinc98
    Sic One
    • Sep 2005
    • 3027
    rough shake
    asked this before and never got a answer. my car is now worse. So what its doing is when I go about 70mph the shifter shakes a little, speed up to 75mph and it shakes more. If I push the clutch in the whole car shakes violently, never did that before. any ideas???
  • shineynitelite
    TURBO SPINNINNNN
    • 5715
    check your mounts
    Originally posted by FortiethStang
    Shagwag, were you in the car craft auto x last year? I remember a wagon running the course..
    • RayK
      No mods............
      • Feb 2004
      • 6396
      Turn off the engine when the clutch is pushed in and see of the shaking stops.
      • SicLinc98
        Sic One
        • Sep 2005
        • 3027
        what will that tell me? Ill test it on my way to the race
        • RayK
          No mods............
          • Feb 2004
          • 6396
          If the shaking stops, you have a problem forward of the clutch. I suspect it's a bad mount, shock, out of balance driveshaft, or bad u-joint.
          • SicLinc98
            Sic One
            • Sep 2005
            • 3027
            thanks ill see what I come up with then
            • RayK
              No mods............
              • Feb 2004
              • 6396
              Have you had the tires balanced lately? I had a tire move on the rim throwing it out of balance. Bend or damaged wheel?
              • SicLinc98
                Sic One
                • Sep 2005
                • 3027
                no there all fine
                • KickAssFlash
                  TCS AutoX Driver
                  • 11568
                  Mine does the EXACT same thing, but it stays the same when I push in the clutch. Only goes away when I slow down. I'm in the midst of replacing my driveshaft U-joints, I'll let you know what happens.
                  • RayK
                    No mods............
                    • Feb 2004
                    • 6396
                    Did you get the driveshaft checked for balance? I ruined a driveshaft for my Ramcharger once when I changed the U-Joints. Vibrated like a SOB over 45.
                    • allstock93gt
                      does not visit often!
                      • 1959
                      u joint or driveline angles would be my guess
                      • SicLinc98
                        Sic One
                        • Sep 2005
                        • 3027
                        my car is dropped but its getting worse
                        • roast'em89
                          let the smoke roll
                          • 275
                          u joint
                          you gotta pin it to win it
                          • RayK
                            No mods............
                            • Feb 2004
                            • 6396
                            Originally posted by roast'em89 View Post
                            u joint
                            Sometimes they look good, but are bad and you need to test them. I had a back u-joint let go on a old Fairlane I had and the driveshaft dropped down. Good thing I was only going 30 mph.
                              Driveshaft is fucked mang! thats exactly the problem i was having until i installed that driveshaft you sold me!
