Why cant I read what code its throwing
  • KickAssFlash
    TCS AutoX Driver
    • 11568
    My 95 Mustang is throwing some sort of code. It comes on only when I drive it, and doesnt come back if you shut it off until you drive it again. So I'm pretty sure its an 02 sensor. But I was going to check it just to make sure. I took it to two different shops and they both could not read what code it is throwing. WTF? Is this some wierd cross over year where you could plug in an OBDII end, but its actually not?
  • shineynitelite
    TURBO SPINNINNNN
    • 5715
    wtf.. it has teh obd2 plug and the code doesnt stay? should stay on for 40 or so starts and shut downs no matter what (unless erased obviously)
    Originally posted by FortiethStang
    Shagwag, were you in the car craft auto x last year? I remember a wagon running the course..
    • Osiris22
      • 1364
      HMMM. My Dad has a 95 F150. It's ODB1 and it follows the same fucked up
      pattern. It doesn't throw the check engine light on until after a mile or 2.
      I Know as of today that the ODB1 code reader for Ford is only $20 bucks.
      Oh well it's his prob.
        I'll help you pull that code this weekend sometime. Give me a call.
        • KickAssFlash
          TCS AutoX Driver
          • 11568
          Anybody know what in the world is going on?
          • D3thM3tal
            IT Pro / Mechanic
            • 3665
            Same thing happens to me, the check engine intermediatly comes on and goes off, I really think it has somthing to do with the 02 sensor and how modified the xhaust system on my truck is.. Anybody else ever expirence a flashing overdirve light column shifter before? Whenever it happens, I cannot get it to go away.. I pretty much have to restart the computer by leaving the batter unplugged overnight and then it stays off for quite a long time before comming back. I've got a temp sensor on it, and after a bit of driving it seems to hover right around 170-180... I think that is within normal range, anybody know?
            Our problems are probably damn close being my truck is a 95 5.0
            I bleed blue
            • 95 whitestang
              • 3601
              Do not try to use the OBDII plug down by the drivers right foot, instead you will have to use the OBDI connector under the hood in order to read the codes. I have the same connector on my car and it never has worked for me.
              Originally posted by mnstang
              Originally posted by 2 beer
              • 95 whitestang
                • 3601
                You most likely have an electrical problem with your transmission. Possibly a solenoid or wiring issue.
                • KickAssFlash
                  TCS AutoX Driver
                  • 11568
                  Really...
                  Where is that OBDI connector?
                  • 95 whitestang
                    • 3601
                    The OBDI connector is right behind the right strut tower next to the firewall on a 95 stang. I think it is labled for engine diagnostics or something along those lines but dont quote me on that. If you dont have a scanner or code reader, you will have to jumper 2 wires and count the ses light flashes.
                    • D3thM3tal
                      IT Pro / Mechanic
                      • 3665
                      There any way I can have this checked out? I dunno if it really is a problem anywase, its an off-road truck and used on side projects. I probably put 500 miles on it a year.. but they are a hard 500...
                      I bleed blue
                      • 95 whitestang
                        • 3601
                        Ya someone should be able to figure it out, put a scanner on it and see what codes are stored in the ECM.
                        • VELOCITY
                          Pacer's RULE!!!
                          • 2900
                          I have a Ford OBDI code reader that I bought for my work van. It comes with a table that tells what each code means... It's nothing fancy but it works. I only paid like $20 for it, I can't remember where I got it though.
                          • D3thM3tal
                            IT Pro / Mechanic
                            • 3665
                            Checker reads codes for free, or at least in FL they do
                            I bleed blue
                            • 95 whitestang
                              • 3601
                              They do here in Sioux Falls also.
