351 EFI->4 cyl Notch
    alright, as sum may know i just bought a 4 cyl notchback automatic. i have a (i believe) '93 or '92 e350 conversion van with a running 351 w/ fuel injection. i haven't really taken a look at it as i have just decided on swapping it in. the body is junk so it will be cut apart to drop the motor out. i have a brand new van oil pan which works perfect for the fox swap. does anyone know any spec's on the 351 van motor and what tranny is in there, etc..? the motor will most likely be reconditioned over the winter and completely rebuilt w/ trick flow aluminum heads and other bolt ons. does anyone know what computer is in the van?? is it an EEC-IV/V type setup or similar?? i plan on pulling everything, harness, computor, etc, etc.... where can i find a wiring diagram for all of this?? well, thats the end of my question ranting, so if yall can answer a few it would be greatly appreciated
  • Osiris22
    • 1364
    If you got the $$$ then buy the twisted R-Series heads. They flow over 300 CFM out of Box. They are bad to the bone. Then do a 408 stroker. The problem is that U will be limited on intake selection if wanting to go EFI. If U went carb then U could easily have 550 HP on pump gas.
      tranny is most likely a C4 but could be an E4OD depends I guess. I know up until 94 or 95 they where using C4's I think or C6's ahhhhh shit I cant remember
      • sc0tty8
        Raised by wolves
        • 4134
        Its the e40d. I almost bought an auto 4 banger notch, then the dude sold it to someone else, I got whats required to dump a 351w into a stang somewhere I will look...
        Also, you will need v8 springs, buy some eibachs or something, I looked into 4 banger to v8 conversions, my dream is to buy a 4 banger notch and drop in a big bad ass 393 stroker
        No sig for you.
        • sc0tty8
          Raised by wolves
          • 4134
          351w Swap Info.
          Written by: Mat Peirce aka MAT88GT
          Will it fit?
          The deck height of a 351w is 9.480" for 1969-1970 blocks and 9.503" for 1971 and up blocks compared to the 8.2" deck height of the 302w block. This equates to a taller and wider motor. There have been many people who have squeezed 351's under the stock Mustang hood, but chances are at least a 1.5" cowl hood will be needed for the 351w combination. The motor mounts on 351w and 302w blocks are interchangeable.
          Can I reuse any 302w parts on the 351w?
          There are many interchangeable parts between the Windsor blocks. The 351w uses a wider intake than the 302w, but you can use a cobra upper with a 351w specific lower intake. Timing covers, water pumps, and several of the accessory brackets are interchangeable. You do need a FMS power steering and a/c bracket in most cases. Cylinder heads from a 302 can be used on a 351w block by drilling the head boltholes to accommodate the larger 1/2" 351w head bolts. The 302w fuel rail can be modified to fit the 351w by extending the rail crossover tube.
          Will my 302w balancer work on my 351w?
          The 351w uses a 28oz/in imbalance that is the same as early 302's. You can use a 28oz/in 302 balancer on the 351w.
          What is needed to use the serpentine belt setup from a 302 on a 351w?
          The 302 alternator bracket can be utilized on the 351w, along with the reverse rotation water pump along with the air conditioning and power steering brackets. The crank pulley requires a 3/8" spacer available from FRPP between it and the balancer for proper pulley alignment.
          What do I need for exhaust on the 351w?
          Swap headers are a must for a proper 351w installation. There are many suppliers of 351w swap headers and matching intermediate pipes including: Hooker Headers, Hedman, BBK, Mac, and Kooks. Most 351's will benefit from a 1 3/4" primary tube size.
          What parts are a must have for a 351w installation?
          First, you need an oil pan and matching pickup to mount the 351w into the Mustang that will clear the K-member. Moroso, Miloden, Canton, and FRPP all make exceptional 351w Mustang swap oil pans. Note that the FRPP version is a 5-quart capacity design while the others are 7 quarts. Crown Vicorias and Grand Marquis also have a dual sump 5-quart oil pan that will fit the Mustang K-member. Second, an intake is needed. If you are using EFI Edelbrock and TFS make intakes for EFI equipped 351's. You can also use a FRPP Cobra upper with a matching lower, or a 351w truck lower with stock EFI Mustang upper. For carbureted applications there are many companies making 351w carburetor intakes such as: Edelbrock, Holley, Weiand, and Offenhouser. You will need a 351w specific distributor. MSD and EFI equipped 351w Thick Film Ignition distributors will work with the Ford EFI EEC. Any points, Duraspark, or MSD distributor will work with a carbureted combination.
          What block should I use?
          All pre 1994 factory 351w blocks are non-roller designs. Blocks produced before the early 1980's used a two-piece rear main seal. Ford trucks and vans produced after the mid 70's use a stronger rod design often referred to as 'Football' rods because of their football shaped bolt heads. 1969-1970 blocks had a lower deck height (9.480") and provide more compression from the factory. These early blocks also have a stronger thick wall casting design and are often thought of as the strongest factory 351w block. Keep in mind that all 351w blocks are considerable stronger than the factory 302w block. If you need an exceptionably strong 351w block design FRPP and Dart both offer aftermarket 351w blocks in many varieties.
          How do I install a roller cam in my 351w?
          The easiest way to use a roller cam in the 351w is to find a F4TE casting number block from 1994 and later F-series trucks and E-series vans. If you happen to have a block produced before 1994 you can retrofit a roller cam quite easily. The first option is using 5.0L hydraulic roller lifters, retention spider, and lifter link bars with a reduced base circle hydraulic roller camshaft. This method requires machining the lifter valley to accept the spider bolts. Second, Comp, Crane, and Crower make retrofit roller lifter that will allow the use of any off the shelf 5.0L style hydraulic roller cam to be used in a non-roller 351w block. Any flat tappet 351w-302w flat tappet camshafts will work with the correct corresponding firing order.
          What vehicles should I get my 351w from at a junkyard?
          Ford produced many vehicles which used 351w motors including, but not limited to, the following... Mustangs Fairlanes Galaxies Cyclones Torinos LTD's Crown Victorias Grand Marquis Rancheros Cougars F-series trucks E-series vans Broncos
          What about a fuel system?
          The 351w is defiantly going to consume fuel at a higher rate than a smaller motor and you should upgrade the stock fuel system to provide for this thirst. EFI equipped Mustangs should use at least a 190lph in tank fuel pump and 24+ pound injectors. Many carbureted Mustangs use a Holley Blue pump or equivalent, which requires slight modifications to the stock in tank fuel pick-up to function properly. An adjustable fuel pressure regulator should be utilized with both EFI and carbed systems.
          No sig for you.
          • Osiris22
            • 1364
            Originally posted by sc0tty8
            351w Swap Info.
            Will it fit?
            bla bla bla bla bla
            • sc0tty8
              Raised by wolves
              • 4134
              Originally posted by Osiris22
              bla bla bla bla bla
              Nice attitude, I'll be sure to remember that when I got an answer and someone wants an answer.:looser:
              No sig for you.
              • Osiris22
                • 1364
                remember when U got another C/P. that's not 20+ years old.
                • sc0tty8
                  Raised by wolves
                  • 4134
                  c/p?
                  No sig for you.
                  • Osiris22
                    • 1364
                    c/p?
                    C/P = Cut and Paste
                    N/A = Naturally Aspirated
                    S/C = Super Charged
                    Holy fuck. Do I need more specs.
                    • sc0tty8
                      Raised by wolves
                      • 4134
                      ....so I copied some info when i was looking into a 351w swap and saved it, someone needed it, instead of saying hey go to corral.net and search, I pasted what I had, and what I thought was some good info for those looking into the swap...
                      I'll see what else I go to "c/p" and see if its older...
                      No sig for you.
                        351w Swap Info.
                        Will it fit?
                        Good info. It actually makes the 351 swap sound easy.
                          if i remember correctly edelbrock has a coupla good efi intakes for the 351 efi.
                          and the tranny is e40d as i remember
                            its a 94 van so it should have a roller block. did they produce roller blocks for the whole 94 model year or was it mid year or sumthing like that??
                              and finally, is the 94 351 have mass air?? kthnxbye
