Speed density Mods
  • 87lxmustang
    NA rocks!!
    • Nov 2003
    • 210
    Speed density Mods
    Has anyone installed a mild cam such as an "E" or a trickflow
    stage 1 in a speed density car? My current combo includes
    Trickflow heads,ported lower with a comp box upper,70mm
    throttlebody and spacer,adjustable fuel reg.,offroad H pipe,
    3.55's, 1.6 roller rockers. The car dyno'd at 285hp with only
    299fp torque. At 2940lbs it's run 12.79 at 109.9 mph with only
    a 1.99 60 ft. on drag radials. The air fuel ratio at full throttle
    was spot on at 12.5/1 . The driveability now is great and I'm
    currently installing a typoon intake to bring up the torque number,s. What i'm concerned about is losing some drivability
    with the cam install. Also i'm still running 19lb injectors with fuel
    pressure around 53lbs.Obviously at some point I'll have to convert
    to mass air but it's fun running fast on speed density.
    Any info would be great
    87LX hatch 12.635@109.21 Speed Density
    12.259@112.41 Mass air and Stage 1 cam
    311RWH 326 RWT ( 5-1-06) NA
    347 CI 370 RWH 374 RWT (9-1-10) NA
    the typhoon is a great idea, i used to have a comp box on a stock lower (mike now has that comp box on his lx), and then went to a typhoon and felt ALOT of power everywhere in the powerband, especially under 3000 rpm it was a huge difference, night and day.
    i'd think either one of those cams would be a good choice regardless, even if you had maf. i had the TF stage 1 on the old combo... it is still pretty mild, but very noticeable and if you have some heads and intake (like you do) to take advantage of the cam, it's a very worthwhile thing to do imo. (mike now has my TF 1 cam)
    i'd think with the cam and intake you're going to be past 19lb injectors anyway. now i'm not a speed density expert at all, but couldn't you just get some 24lb injectors and lower your fuel pressure? i don't see why that wouldn't work if you tuned the pressure on a dyno?
    not much help but i'm sure someone else might chime in too with some better info.
    (do you have a better fuel pump in that beast???)
    • Roast'em
      has posted this
      • 5496
      Speed density is awesome. It's like the purest form of 5.0 performance because every little thing helps and those cars run hard with little mods. I have no idea what a cam or injectors will do since my old sd cars only made it as far as you with an intake and gears etc. I wouldn't count on it running too well. If I was you I'd get some 4.10s and maybe some better heads. Even with the stock cam that car will haul! shit, it does right now.
        dude rob, he has trickflow heads!
        • Roast'em
          has posted this
          • 5496
          oh, duh. For some reason I thought they were stock. Gimme a break I just woke up and I was boozin last night.
            i would check out a crower 15511 cam for SD. supposedly that cam is the shit for speed density.
            -Tim
              duration at .050'' 219 intake, 224 exhaust.
              lift with 1.6 rockers .469'' intake .496'' exhaust
              lobe center 114 degrees (that should help for SD)
              this is what i could make out from the crower website, but the numbers were really small.
              • 87lxmustang
                NA rocks!!
                • Nov 2003
                • 210
                Thanks, I printed a copy off the Crower website.Know where I
                can get one that would be less expensive than their online
                store? Even an AFM cam is cheaper but they won't tell you the
                spec's,only that it will work on speed density cars.
                Tim
                • Roast'em
                  has posted this
                  • 5496
                  AFM cams are cheaper by 25 bucks. For something as important as a cam, I wouldn't base the decision on price when it's such a small difference.
                  I'm sure someone on the corral could dig up specs on the AFM for you. I found them for my cam before I bought it.
                  • 87lxmustang
                    NA rocks!!
                    • Nov 2003
                    • 210
                    The price difference was more like 60.00 and I'm always looking
                    for the best bang for the buck!! But how about it,anyone know
                    the AFM cam specs for one that will work in a speed density car?
                    Thanks for the feedback guys!!
                    Tim
                    • CaptCrunch
                      Damn GM Guy!
                      • 1932
                      Keep in mind that the main problem with SD is that it relies heavily on vaccum and pre programed peramters in your ecm. Keep in mind that you can play tricks to fool your ecm into thinking there is more vaccum so it will read and then final tune it with the chip. You can also get the whole works to run on just the tps, but it is rather tricky and will require a fair amount of work to tune it. You will need (or know someone who can) equipemt to see what is happening and equipment to make chips. At that point you are probably better off switching to a standalone or to a MAF system, but regardless it can be done.
                      The MAF EEC-IV is a nice system to use for performance and does very well with power as long as you can get an MAF calibrated for your needs and that will not be a major restriction in the induction.
                      -1968 Chevelle
                      • Roast'em
                        has posted this
                        • 5496
                        Originally posted by 87lxmustang
                        anyone know the AFM cam specs for one that will work in a speed density car?
                        5.0/5.8 tech forums, do a search for speed density cams and there are endless topics about the crower or afm cam. It sucks that we can't help but that site is just full of hardcore 5.0 techies. It's impossible to match a resource like the corral.
