Short throw shifter question
    I picked up a cheap short throw shifter, it might be a pro 5.0 not sure. Anyways, there are what looks like two larger screw holes both top and bottom if you are looking straight at the shifter. Right now there is nothing in them. I was thinking these might be for "bump stops" or whatever, where you adjust how far the shifter can travel forwards and backwards. I remember outrun saying something about adjusting this sort of thing when he installed his short throw shifter. If this is the case, should I run to the hardware store with it to get a couple of bolts so the shifter travel can be stopped at some point, or should I not bother and just install the shifter as is? Thanks.
    You need those bolts. Go to the store and get the bolts. Those are what stops you from breaking shift forks.
    The Cool Website for Late Model Ford Mustang Enthusiasts !
      Ok yeah, the holes are exactly where they have the "stop bolts" pointed out on that diagram. I'll just run to the hardware store and get what I need. Thanks Chris!
        No problem mang. You're gonna love the short shifter. I think its one of the best mods that I have done so far.
        • SicLinc98
          Sic One
          • Sep 2005
          • 3027
          In that case i might want to go pick some up
            lol, you said that the stock shifter was fine after testing mine, went as far as to say it was better than the pro 5.0 and now you buy a short throw one. you homo.
              stock shifter better than a pro5.0??!!!!???? seriously
                Maybe he just doesn't like workin another mans stick.
                • SmithEvo
                  Poppin' VTAK yo!
                  • Nov 2004
                  • 25468
                  Asians dont have sticks big enough to do anything with
                  Not at the table, Carlos.
                    I'll show you a meat pipe. Then I'll show you how to do the 5 knuckle shuffle with your piss pump, you silly bitch.
                      Mr. "I love my stock shifter" gets a short throw finally.
                        Stock shifters are sweet!
                        Untill you try a short throw, and you suddenly feel dumb for not getting one sooner.
                        pro5.0 ftw!
                          Well with all the hype, I figured I would try one out. If I don't like it, I'm yankin it right back out and throwing the stock one back in. Never know, I might still do that. But I'm open minded and figured I would try one out for a while. I still have had no problems with the stock shifter, and I would never have spent the money for what they want for a new short throw shifter. So there!
                            When it comes to shifters...shorter is better...
                            • sc0tty8
                              Raised by wolves
                              • 4134
                              Like dewd, no stop bolts is like 10 more hp and allows the v-tac to come on sooner
                              No sig for you.
