Injector Cleaning
  • Bagd72
    • 702
    Injector Cleaning
    I have a set of LT1 injectors that someone left sit for 4 years with gas in them. I need to know who can clean them locally. They are off of the car. Thanks for any info.
    04 Dodge Ram 2500 Cummins. Edge Juice w/ attitude, 5" turbo back exhaust, S+B intake
    72 Chevy C-10. LT1, bagged, shaved, 20's, etc.
    And lots more projects.
    not a big deal,carb spray and let em buck
    • Bagd72
      • 702
      Should I hit them with some voltage to get them to open when spraying them down? Thanks.
      • RACER
        Street Racer
        • 806
        t.p.i.s. in chaska, (cottrel racing). they will flow them before and after
        • Dustball
          My title here
          • 3251
          There's a carb shop on White Bear Ave right by Napa. They do injectors too.
            TPIS in Chaska will clean/flow them for you. That's where I had mine done.
              I don't know if you want to hit them with voltage, if I remember right injectors are fired by grounds????
              • sc0tty8
                Raised by wolves
                • 4134
                So the ground is triggered, you still have to supply a positive signal.
                I had read an article on a DIY injector cleaning, pretty much what they did was hook up a hose to the other end of the injector, the side you would push into your intake or whatever, and they ran an old fuel pump to that hose, and then cycled voltage to the injectors.
                I can't find the link but it went into more detail on how to clean them yourself, pretty much back flush them since there is a screen in the tip of the injector.
                You could prob fire them and see if they are plugged with a pressurized fuel source from them tip and knock all the crud loose...
                No sig for you.
