What are peope running for springs. My car sits way to low. I am not sure what springs are in it but it rubs all the time. Only suspension mods are 01 front spindles, s&w control arms and springs. I just want to get the rubing to go away.
Lowering springs?
Well I dont think thats the problem. This is for Andy's car. If you look at the front as it sit there you can barley stick your finger between the tire and the rim. I will try and get pics to help show the clearence.Originally posted by StangerJonI run motorsport C springs.
fronts are specific rates at 660 lbs, and the rears are a progressive. I forget the rates of them.
does that mean your five lug? you may try swapping to 94-95 front spindles, I believe they are 1/4" narrower.Originally posted by xjfishwe mustang guys are camerowned
mmk, I figured it was for his car.
if you want, I have my stock springs. they are for my svo, dont know if htey are the same as the 4 banger springs. you guys can throw them in and check if that helps.
edit-is there any isolators in??
when I first put in my c springs my car was lower then shit, then I put in the upper and lower isolators and it lifted the car about 1/2"Last edited by StangerJon; 07-12-2006, 05:30 PM.
