Door molding tricks?
    Anyone know how to get the moldings that run down the door to flaten out? Mine are slightly out of wack. I thought I heard somewhere to take the metal strips out of them?
    Thanks for any help.
    Possibly, I dont know. I just thought i would say that though.
    Bump or whatever
    • moretoyz
      • 1189
      Did you PEEL them off or something? Taking them off that way destroys them.
      :geeza:Member of WCR by proxie... I'm selective....I only kill the Fox's that ask for it
        The moldings? No. I just want to make sure they go on smooth since I have a 86 and they don't sell those moldings new.
          Yes, you will have to take the metal strips out. That is what I did, I think Nick helped me with the mouldings. I remember using a heat gun as well, it takes a little while.
            careful, they dont make those anymore!
              Did taking them help make much of a difference?
                Yes, with the metal strips still in, they have a tendancy to curl. With them out, they will lay flat against your door with no problem. I used 3M double sided adhesive to attach them to the door. Been on for 3-4 years and no sign of problems yet.
                  Yes it's an old trick that works. Get a heat gun, not some pussy hairdryer, but a big "fuck off" linoleum stripper. Lay it flat on the garage floor, metal strip facing towards the ceiling. Then heat it up moving it back and forth making sure you do not melt it. Take a needlenose pliers, and get it worked up from the beginning. Ever see a sardine can, how you peel the lid back? Do that with the needlenose. Twist the metal strip around the pliers while heating. Get your gf to do the heating or the peeling. Works better with two people. Alternate heat in 5 inch intervals sweeping back and forth taking care not to melt it. Take awhile, but they will lay flat for you forever with some good moulding tape.
                    I'll try it. Thanks...hopefully I can pull this off because they are already painted lol.
                    • Bmikkalson
                      • 3333
                      If you put the molding in the Freezer, the metal comes off better then the heat gun and you dont risk melting them
                      MR,POWERS
                      "Well now you know. Cops break laws all the time, luckily for them they aren't held accountable for most of their infractions."
                      New Generation Auto, CJ performance Package STAGE 2
                        Are you serious? I have never heard of that...
                        • T BONE
                          UNCLE BEARD
                          • 11494
                          Probably he knows his shit
                          • Bmikkalson
                            • 3333
                            Ya, Get a little corner started then the metal just rips right off
                            MR,POWERS
