1st/2nd gear clunk fix!
  • Joe Goebbel
    2012 370Z Nismo
    • 2318
    For all of us with the tremec 3650 5-speed transmission with the 1st/2nd gear clunk.
    From the stangnet thread:
    3R3Z-7107-AA RG-TRA/AX SYN BLK $289.77
    3R3Z-7102-AA GR ASSEMBLY-TRANS INTERM $123.18
    3R3Z-7124-BA SYN ASSEMBLY TRANS $102.86
    All parts are due in from the plant this week and should be available through dealers within a few weeks.
    All of us with this gear clunk problem can finally get it fixed.
  • Sleeper
    Reasonable volume.
    • Nov 2003
    • 14888
    What causes the clunk in the first place?
    • Joe Goebbel
      2012 370Z Nismo
      • 2318
      Here is the thread from Mach 1 registry and stangnet.
      For the question on what causes the problem. I would guess the parts they are replacing to cure it. Not to be a smart a** or anything. One of the transmission guys on here would have to get technical. I'm not the guy to do that.
      • DNeinstadt
        Administrator
        • 12578
        You can also drain the fluid out and refill with 3.2quarts of ATF, instead of the factory fill of 3.4q.
        It helped my '01 Cobra a little bit. But not much.
        Dan
