Fuel system help!?!?
  • 88fiveohGT
    • Mar 2005
    • 665
    Ok i got my car back together after a bottom end freshening and a head/cam swap. Problem is the 255lph fuel pump that was also added wont shut off when you turn the key on. It just keeps buzzing and it sounds almost as if theres a leak coming from the passenger side fuel rail but i dont see any fuel coming out. It worked fine last thursday and i cant recall changing anything since then. any idea where to start for diagnosing this problem or what the problem is? thanks.
    -Andy
    if it wont shut off with the key off sounds like you have a hot wire straight to the battery instead on it being switched...
    • 88fiveohGT
      • Mar 2005
      • 665
      no its when u turn the key to ON. It should built pressure for like 2 seconds and then shut off but it stays on.
      -Andy
        if thats the case and you are hearing a fuel leak on the passenger side maybe your fuel pressure regilator is screwed and not holding pressure making the pump stay on??!
