MAF
    MAF
    What size mass air and throttle body would be good to install on a 94 cobra that has full exhaust, 3.73's, and underdrive pulleys?? I was considering a cold air intake and thought a new MAF would help. C&L has good options with either a 73mm or 76mm MAF unit and inlent tube. Should i get a 70 or 755mm throttle body to accompany it or is the cobra's 65mm good enough?
  • FASTANG
    not really, but someday
    • 1294
    You could go with a 75mm MAF and if you have stock H/C/I the 65TB will be good enough for now.
    Taryn
    Want to see more? -->'95 GT
    • Meegs
      AA for Mustangs
      • 3062
      I have a new C&L 76mm that i will sell for cheap $90 sound good? a 70mm TB will be more than you need and will have lots of room to grow into. if you get a 75mm TB you will have troubles with idel! i'm S/c and n02 and run a 70mmTB. when you barely step on the throttle the 75 swings open so damn much you'll either stall your motor or burn up the rear tires. fun in the begining but after about a month it starts to suck big time. it takes a big motor to validate the 75mm TB, IMHO.
      93 Teal Cobra #2531
      Turbo Cobra MAFIA
      1 of 452
        yep 70mm t-body is plenty.
        And the mafs from Meegs sounds like a good deal.
