omg stupid car!@!!
  • jjhirsch
    hirsch
    • 3776
    omg stupid car!@!!
    from other post i have asked about a starting problem that it takes like 30 secs of cranking to start it.
    now today at 1 pm ( warm out) it wont start at all.
    new battery, 40ibs of fuel and pump is buzzing,
    how can i check spark?
  • KickAssFlash
    TCS AutoX Driver
    • 11568
    Take a plug out and hold it against something metal while someone cranks the motor over. But I thought I remember you saying that you didnt replace your fuel pump when some knowlegable people advised you to do so.
    • jjhirsch
      hirsch
      • 3776
      oh that was for my nx kit but i cheacked fuel pressure at 100 shot and the fuel pressure didnt move so i ran a 75 to be safe.
      but my new fuel pump is for when i run 100+ shot once i have time to put it in.
      • jjhirsch
        hirsch
        • 3776
        could it be distributor cap and rotor?
        maby i should cheack them out
        how long do those last?
        • Joe Goebbel
          2012 370Z Nismo
          • 2318
          It's possible you have a spark problem. I would think you would hear a miss periodically though. What kind of spark plugs are you running with the NOS? I hope they are not factory plugs, with the factory gaps.. EEK! Check the plugs and make sure none of them are melted from the NOS. If they are, let us know.
          You can do what Kickassflash said. You will see a nice strong arc if everthing is correctly. Make sure you do it in a dim area. It'll make it easier to see the arc. Do one plug at a time.
          I remeber checking Joe M's POS car and it had a weak spark due to the battery. You could pull all your cables off and see what the battery has for juice after sitting all night. Should be in the area of 12volts, but I don't remeber you saying anything about having problems with the engine turning over so this probably isn't it.
          Look for a owners manual online. I'm sure it'll tell you when you need to check the distributor and stuff during city driving. I usually just change things out when the manual says to check stuff. Might be overkill, but it's just how I do things.
          • jjhirsch
            hirsch
            • 3776
            well ill check those things but i dont get why once it starts it is fine and can start all day after that no problem it is only when it sits over night.
            and yes i have colder plugs in there tomarrow i will take them all out and regap them.
            • Joe Goebbel
              2012 370Z Nismo
              • 2318
              Might have moisture in the distributor. After you drive around the heat evaporates it. Open up your distributor before you start it in the morning and look for water.
                clean your maf
                • SicLinc98
                  Sic One
                  • Sep 2005
                  • 3027
                  Hold the plug on your tounge and crank it, Youll know if its good......Yea sounds like dis and cap problem to me. There cheap enough replace them
                    What about a loss of fuel pressure from a leaky injector? This could present similar starting woes. What about the IAC not functioning? Many things, but fuel or ignition from the sounds of it.
                    • jjhirsch
                      hirsch
                      • 3776
                      Originally posted by 2 beer
                      clean your maf
                      hmm could it really be from a maf because it dose seem to be started after i put the cold air intake on it.
                      hmm
                      how do u clean one?
                        rubbing alcohol on a Q-tip. The oil from oil style air filters likes to gum up on them
                        • trickedponyracing
                          giggety giggety
                          • 146
                          You can also use Carb cleaner to spray the sensor off.
                          When your bottle goes low your back to slow, always being blown is the only way to go.
                            Also don't forget check valve in the pump, and AFPR.
