Where are all the ground straps on a mustang?
    want to check them and make sure they are all good and intact. Cant find ot in the haynes and it isnt usually a topic of conversation. Let me know
  • worduphomefry
    no fat chicks
    • 11982
    don't know if it is different on the sn95 but on the fox theres one behind the drivers side head
      I knew of that one, but I think there are more, one being under the a car connecting the chassis to the frame of something. I dont know where or if there are more someplace else. I am having electrical problems carry over from last year and I want to cover all the bases before I start blaming componants or rewire everything.
        what kind of problem are you having
        • Turbo302
          • 1528
          Don,
          Look for green headed bolts. I think Ford "generally" coats all the chassis grounds with some sort of green mark so they always know where they go.
          Are you having a ground/interference problem with a certain system (abs, security, ignition?)
          You could try to add a dedicated ground to the problamatic system to see if it changes/goes away.
          Tim
          1988 5.0 Notchback
