Which brand would people suggest on buying???? I am correct in thinking that you need one if you are faster than 14.0 at the track?? Let me know, I think I should pop one under my car.
Thanks
I put a UPR one on my car. It's a two piece bolt togather, so I didn't even have to take off my drive shaft to put it on. It's also zinc coated. I thought it was a pretty nice piece for $40. Good luck.
I went with the Jegs safety loop, its one piece, so you have to unhook driveshaft, but I was putting an aluminum shaft on anyways it looks nice, made specifically for 79-93 stangs
You pretty much have to drill through the floor. I don't know of anyone that makes one unless it's welded in. I have a metco that I bought from jds performance. I don't think you need one until 11.99 or running slicks but I would definitely recommend one. If you break a u-joint you'll be glad you have one. Nick
Knowlton's Thunderheads www.twolaneracing.com
RF never bugged you about that 11.99 thing did thay Tim?
I think everyone should have one! fast or slow! If a the front of a driveshaft goes there is a possability of the car fliping but it would have to come apart at high speed which is un unusual. usually they come apart at launch. Blkthndr's rear u joint came apart and did alot of damage from the driveshaft floping around.
If anyone is interested I can build custom loops and weld or bolt them in for about $40. I will also do a rear one for $30
Is this something new that they are doing. 14.0 and faster is alot of stock cars even or is this only for cars that were not this fast from the factory?
