Sheared bolt removal help?
  • SFC
    I know drama
    • 24976
    I know there's some sort of ratchet socket or something of the sort to remove a bolt with a sheared off head. Long story short, I was replacing my exhaust, and the head of one of the bolts that connects the mid-pipe to the cat sheared right off. So now I have about an inch of bolt sticking out of the cat that I can't get out easily. No leverage from underneath to use a vice grips, I tried (no lift to use to get it up high), and I don't have anything else to use. So, someone anyone have a tool or suggestions? The bolt is rusted to hell. Literally all the threads rusted off besides the ones that are actually holding it to the cat, which accounts for a total of about 4 threads. The other bolt came out no problem with an impact wrench.
    Blah blah blah, I need to get exhaust on the winter beater this weekend since the honDUH is going into storage so... if anyone has ideas/suggestions/help it would be greatly appreciated. You can PM me, respond here, whatever.
    You stay classy Chet Beireis
    I can't wait for that ****** to take all the credit
    PITBULLS KILL KIDS!!!
    ROTTWEILERS EAT BABIES!!
    Celtic Mafia
    6.2L Mafia
    319whp of fury
    Use a torch, the big red wrench. Heat it up, or cut it in half.
    • SFC
      I know drama
      • 24976
      I did torch it, got it nice and red hot. Again, no leverage. Tried with a vice grips but it wouldn't budge. Breaking it off seems like a worse idea... then I'll have absolutely nothing to back it out with. At least with the nub I have a hope.
      Celtic Mafia
      6.2L Mafia
      319whp of fury
        Hmmm, I am having trouble picturing this. Post a pic, that will help.
        • MontiMach
          Wanderer
          • 862
          You can try an Easy-Out.... craftsman product (Sears).
          It worked for me once, and another time the easyout snapped off.
          Basically you drill a hole in the center of the bolt that was broken off, run the easy out into it, and keep cranking the easy out (left handed threads) until the bolt comes out or the easy out breaks.
          Enjoy.
          BSM Flunkee
          • SFC
            I know drama
            • 24976
            mspaint is not functioning very well. Basically imagine two holes in a wall. You screw two bolts in. When unscrewing them, the first bolt comes out jsut fine. The second bolt comes out 3/4's and then the head snaps off. The rest of the bolt is still there, just the head is gone. That's basically what I'm up against. Except it's on the bottom side of the truck Meaning I have about 180degrees of motion max, and in reality about 90 degrees because there's shit all over the place on the bottom side like the frame
            Celtic Mafia
            6.2L Mafia
            319whp of fury
            • deion82
              jdspowdercoating
              • 574
              Can you weld a nut to the top of the busted stud?
              • MINNESOTA 5.0
                I FIX OTHER PEOPLES FUCK UPS
                • 2852
                if you can heat the thing cherry red hot then i have a stud remover you can borrow.
                let me know where you are and maybe i can help.
                89' NOTCH- 327 TURBO, C4
                • SDK
                  #1McMoppoFan
                  • 12342
                  Cut it off and then drill it out. Then use a bolt and nut when you put it back together.
                  • allstock93gt
                    does not visit often!
                    • 1959
                    well if the other end of that stud is not a bolt head more than likely its a splined stud and you would need to just pound it threw the hole. or again blow it out with a torch and use a nut/bolt they always work well and easily replaced later.
                      i also have a stud remover if ne be
                      • Dustball
                        My title here
                        • 3251
                        Stop by Sears, Northern Tool, or Fleet Farm and pick up a set of bolt-outs.
                        Here's an example-
                        • SFC
                          I know drama
                          • 24976
                          Thanks for all the responses, been a while since I checked this. Blazer is currently at my place in shakopee, it was down at my dad's house. My uncle said he would take it in to work, he works for the gas company, and have one of the shop mechanic's do it. If that falls through for some reason, I'll let you know o.O Thanks for the responses.
                          Celtic Mafia
                          6.2L Mafia
                          319whp of fury
                          • Mullet Tuner
                            • 15906
                            I cant believe heat and a vice grip didnt work. I had to use this method on like 4 of my exhaust bolts on my beater.
                            Originally posted by Gerald
