valve covers + CNC machine
  • J-Rod
    few words, many talents
    • Sep 2005
    • 427
    If someone has access to a CNC router you should be able to make some pretty cool stuff. I wish i had one. anyways if you can make me a set of billet valve covers I will provide you with the Oh So expensive aluminum to make yourself a fancy and very unique set of your own.
    These should make those cool fabricated covers look like the piece of tin that they were created from.
  • TurboX2
    friend of the machines
    • 3245
    $400 valve covers anyone? :idiot:
    Dan Simons
    • HAMMAR
      • Sep 2005
      • 340
      $400 would be dirt cheap... I think you would need to triple that figure....
      Regards - Randy
      GT40
        Billet covers are not cheap.
        • 93SVT
          CLEVON
          • 7226
          J-rod, I asked around, and to remove that amount of material would require some pretty crazy tooling, I'll keep working on him, we may be able to work a deal out where we just buy the inserts for the cutters... but if the cutter broke while doing it your talking $700 so there is som erisk for them taking on the project, even if we provided the inserts... and the alum... Id be happy to help design them using solid works or ProE, but as far as having a hook up on getting them machined I may not be able to, but like I said I'm working on it
          • Fastrnu
            • 265
            I own a machine shop spiecializing in custom automotive componants and would be happy to help you out here. If you're providing the material we could work out a pretty good deal. Give me a call. Custom Motivation at 763-286-5235
            • J-Rod
              • Sep 2005
              • 427
              I was actually thinking that for my car a two piece design would be nice. You would be able to cut the deep base from both sides. a top cap would be removable with seprate bolts. valvetrain adjustments and inspections would no longer be messy with 0w-30 oil.
              • J-Rod
                • Sep 2005
                • 427
                Ill get some goodies and probually check you out. I'm going to need some other stuff made too. any body else out there?
                • J-Rod
                  • Sep 2005
                  • 427
                  blah blah blah
                    Originally posted by J-Rod
                    blah blah blah
                    Ahh! How did Charlie Brown's teacher get on the board!!!
                    • J-Rod
                      • Sep 2005
                      • 427
                      I dont get it
                      • Mike Neal!
                        www.AllamericanoutdoorMN. com
                        • 3092
                        I dont get it
                        me either
                        • Sleeper
                          Reasonable volume.
                          • Nov 2003
                          • 14888
                          i've thought of doing aluminum valvecovers and have access to a cnc. ls1 valve covers are about 1" tall so there wouldnt be too much waste...plus the coil packs could be moved for a clean look.
                          good luck with your project
                            Hamburger makes something like this for small block chevy's that dont have centerbolt valve covers, you could steal that design
                            • 93SVT
                              CLEVON
                              • 7226
                              the design is the easy part, its the machine work and materials thats a bitch
