Carb/ Nitrous Questions
  • Got Diesel?
    Perfect Combo- Work and Play!
    • Sep 2005
    • 1205
    Installing new NX kit have some questions about the micro switch mounting on a Holley carb. Am I missing something? Is there a easy way to mount that thing or is it one of those things that you just have to make work? I am going to admit that the carb thing is new to me and frankly a little frazzled by it. If you have any suggestions, a trick that i'm missing, or just to say "Dumb ass" let me know. Also another question, my old carb spacer had a hole for vac. how do i get vac. from it now with the NX plate. FYI don't have enough room for both spacers.
    89 Mustang 351ci
    470 rwhp 520 tq
    10.94@ 126
    Dumb Ass !
    Actually i dont know im a post whore, im gonna keep my eyes open on this since my 77 might get N20 in the next yr or 2
    • Got Diesel?
      • Sep 2005
      • 1205
      Walked into that didn't I
      89 Mustang 351ci
      470 rwhp 520 tq
      10.94@ 126
        you get a carb with the vac. port in the carb... or eliminate your power brakes...
        as far as the micro switch I am a lazy ass... so I would just tape it to your shifter handle, then all you have to do is squeze.
        • HAMMAR
          • Sep 2005
          • 340
          I don't know what you need the vacuum source for, but if it's for your vacuum advance, you can typically connect that to the vacuum port next to the right front corner of the Holley baseplate. This is manifold vacuum and will work well for your vac advance.
          Hope this helps..
          Regards - Randy
          GT40
            you did tell us to call you Dumb ass.....
            • Got Diesel?
              • Sep 2005
              • 1205
              [QUOTE=budderigs]you get a carb with the vac. port in the carb... or eliminate your power brakes...
              Yep, you got the idea but you must not own a fox stang or else you would not be telling me to take brakes away New carb.... hoping for more options than that. Think it's possible to tap a line in the NX plate?
              89 Mustang 351ci
              470 rwhp 520 tq
              10.94@ 126
                so your doing an rpm activated switch instead of a push button huh?
                • Mustangmatt
                  The bobs...
                  • 10806
                  did it come with a lil mini bracket? just bend it and make it work or get some sheet metal. this switch is VERY important, you do NOT want to be running nitrous on part throttle. Make it work whitie!
                  • carnutz
                    Resident Rearend guy
                    • 832
                    I have a couple of really cool brackets for the micro switch, Edelbrock makes a slick one that works off of the secondary linkage. Compition products (?) makes an even better little bracket that is fail proof. Well work the $15-$20 to make it work correctly.
                    IIRC MAS has the Edelbrock or maybe a NOS carb switch bracket in stock....
                    www.haulin-ass-motorsports.com
                    Local quality work at a reasonable price.
                    Local Moser Engineering dealer.
