pulled some codes today
    ok, i picked up a digital code reader today and i pulled the codes.
    for the KOER i got 33 (egr valve not opening properly), 41 (HEGO (HO2S) sensor voltage low/system lean)
    i am pretty much sure that the 41 code was tripped because of my passenger side o2 sensor.
    what do you think about the 33 code? does that mean that i need a new egr valve?
    i cleared the memory codes from a long time ago, and when and if the ce light comes on i will pull the codes again to see what i have.
    thanks for your help,
    Tim
    i think it's the EGR valve position sensor... it's pretty common on these cars it seems.
    • mikeoxsbig
      • 392
      check to make sure that the green vac. line did not melt on the egr tube coming up from the header.
      Beer consumption specialist
        i replaced that vacuum line last year, i am pretty sure that it is the egr valve that is acting up.
