cars missing.
  • Mike Neal!
    www.AllamericanoutdoorMN. com
    • 3092
    cars missing.
    well today i was driving around. when out of no where my car just starts missing? i had a disributor laying around so i put that in and it still does the same thing. we ohm'd my coil and it read good. all my wires are intact. what else could it be? where should i look?
    i would like to go to to porkys so the sooner someone replys the better!
    thanks,
    mike
    Mustangless
    • 18133
    Fouled Plugs? Check the gap?
    • TitaniumGT
      • 11042
      Did you check it in the dark and look for an arcing wire?
      446RWHP and 585RWT
      Vortech S-trim
      346rwhp and 314rwtrq
      • Mike Neal!
        • 3092
        just went and checked and there was no arking going on.
        it almost seems like its backfring.
          Mustangless
          • 18133
          Check Timing?
          is it carb?
          check vacuume, check timing, check your jets and stuff on carb also
          • Mike Neal!
            • 3092
            its efi.....
            i checked timing.
              Mustangless
              • 18133
              Timing is good, Spark is good. Still seems like its backfiring?
              Injectors gone to shit maybe?
              • Mike Neal!
                • 3092
                just put them in last saturday.
                • Joe Goebbel
                  2012 370Z Nismo
                  • 2318
                  Put the old injectors back in and see if anything changes. Did you change anything else recently?
                  • #10
                    it's probably your TFI module
                    • Mike Neal!
                      • 3092
                      i sold the old injectors.
                      just replaced head and intake gaskets.
                      • Mike Neal!
                        • 3092
                        that was changed with the other distributor i tried.
                          Mustangless
                          • 18133
                          Any way to check vacuume or compression? I know little bout efi. Just trying tocome up with things that would cause somethign like this to happen.
