torque specs???
  • Mike Neal!
    www.AllamericanoutdoorMN. com
    • 3092
    torque specs???
    well im going to replace my head gasket and i have arp head studs. i forgot what they are to be torqued to?
    thanks,
    mike
    step 1. 55-65 ft lbs
    step 2.65-72 ft lbs
      Go to Turbomustangs and see what the guys are torquing your HG down to with studs.
      Most go 10-15 ft lbs more on the top and bottom.
      I used 9333s and went 3 steps until I was at 90 top and 80 bottom. I used arp bolts. The studs have more squeeze and require less torque than the bolts
      • 86convert
        • 530
        thanks,
        mike
        I did 75 on the lower and 80 on the top. Also check the washers with the arp's THE DISHED SIDE OF THE WASHER MUST FACE UP, for proper specs. Also I have heard from many people who race that the arp's need to be re-toruqed at least 3 times b4 they will sit properly.
        • Mike Neal!
          • 3092
          thanks.
