Anyone have a Mark VIII fan swapped in?
  • TurboX2
    friend of the machines
    • 3245
    If so, would like to know the dimensions, and what you did for control.
    Dan Simons
    I dont know the demensions but I had to trim it in order to fit it. I used a fan controller fron Dccontroller
      dan get a hold of bill (93svt) i know he once went with the mark VIII fan.
      • Another Mark VIII
        • 358
        22" wide by 19" tall
        [/religion]
        1998 Lincoln Mark VIII LSC
        • Vibrant93
          9SECLX.
          • 1212
          Dan as I am sure you are aware of they are pretty thick as well but there is plenty of meat on them to trim. I run mine via switch combined with a bosch 75amp relay. I've done it this way for 2 years now without any issues. I hear that DC controller is the way to go though.
          The Cobra
          http://i111.photobucket.com/albums/n...awithneal1.jpg
          The Coupe
          https://www.youtube.com/watch?v=Gxl54aGMNxg
          • Novi2KGT
            • 1758
            I've got the DC Controller here too, but I'm just using it on a Taurus Fan...No complaints here.
              kenny, do you have any pictures of your taurus fan setup? i am running one and it cools well, but it has a lot of gaps on the shroud and i know that is hurting the cooling as it could probably cool better if it was a sealed shroud.
              • TurboX2
                • 3245
                I'd be using it on an F150 so depth is no problem. How much is the dc controller? Any links to buy?
                Dan Simons
                  I might have the seal thatgoes between the fan and the radiator Timmah....get a hold of Akromix, it's sitting in his garage right now.
                  • Novi2KGT
                    • 1758
                    Dan, check out www.dccontrol.com
                    It will give you all the info you need. I think mine came to around $120, cause I needed a filter since my battery is relocated. The part number you would need is something like FK-35...I think. I believe it will pretty much run any fan.
                    Tim,
                    The only gap I have is at the bottom of the fan and I mounted it upside down so the gap is on the top. It keeps my car at 180...even sitting waiting to get into Car Craft. For some reason I can't attach the pics I have. PM me your e-mail add and I'll email the pics. What year taurus fan do you have?
                    • TurboX2
                      • 3245
                      That shroud is kinda small for what I want to use it on, what is the size of the Mk VIII fan itself? Might be possible to just mount one into my existing shroud....
                      Dan Simons
                      • theduckylittle
                        Duck uber Alles
                        • 5435
                        I used a box off of a camaro for while... 4-banger mustangs also have a pretty simple device to control the fan... it works off of a ground switch so you have to get it into a water passage...
                        Otherwise, I've seen the old bi-metal probe work just fine on a lot of people's cars. And those can be had at Red Rooster or Napa...
                        -Duck
