Oil Pan Gasket
  • oldstangs23
    • 206
    Oil Pan Gasket
    Since I have to motor out of the car, this is the perfect time to replace the oil pan gasket. This seems like a pretty straight forward job. Is there anything that I should take into consideration so there won't be a future leak?
    Clean both surfaces reallllllllly good Then use the gasket sealer.
    • oldstangs23
      • 206
      Is there a series in which I should tighten the bolts?
        just alternate corners and get black silicone...
        • Blown88GT
          Remy's dad
          • 1904
          get a 1 piece pan gasket it will make life much easier for you!
            I just use the one piece reusable gasket, and put some black silicone (dont goop it) in the corners where it meets the timing cover and in the back, clean, clean, and then clean the surfaces again to ensure a leak free seal.
