Subframes
    Subframes
    okay, i am pretty sure that i am going to pick up some MM full length subframes within the next week or two.
    what are the advantages and disadvantages of subframes? will my 60ft's suffer/increase/stay the same?
    i am running on et streets, with pretty much stock suspension except bbk progressives in the front, stock in the rear, kyb adjustable struts up front, no sway bar, hotchkis lower's, stock uppers.
    the best i have cut so far is a 1.681 and obviously i want to get that in the low 1.6's so i can see that 11.99 pass.
    thanks,
    Tim
  • Joe Goebbel
    2012 370Z Nismo
    • 2318
    Disadvantage: More weight
    Advantage: Watch your front end pull straight up with no twisting.
    • NAZISALEEN
      Afro Samurai
      • 12235
      SO how much harder are the full lengths to install then persay the BBK ones that came in the back of my car (older bolt in/weld in)??
      • bad-speller
        • Feb 2004
        • 943
        Piece of cake. Use a drive on lift in order to keep the weight on the wheels, put the subframes in place and weld them. 1-2 hrs at best, then paint them if you choose.
        Brian
        2006 NASA American Iron Midwest Champion
        2005 NASA American Iron Midwest Champion.
        2010 Camaro SS (My New Racecar, coming soon)
        08 Corvette Z06
        09 BMW M3: Interlagos blue, SMG II
        00 Mustang Cobra R
        95 Mustang Cobra R (#23 NASA AI midwest)
        94 Mustang Cobra (#23 NASA AI midwest) SOLD
        09 BMW X3
        My braking point entering a corner is when I see the corner worker raising the yellow flag for me
        • bullitt
          • 1313
          I liked mine alot and I just got the standard length MM. Driving without the swaybar isn't so bad with the subs on. If anything it should sixty better. I got a 1.85 just walking it out of the hole this past weekend.
          • Blown88GT
            Remy's dad
            • 1904
            the steeda ones are easier to install than the MM we have done both and theres a lot more welding involved with the MM they are basically the same until you get to the support piece that is under the seats the steeda is a 1 piece design and the MM has like 8 pieces that you have to weld together. otherwise they look exactly the same once all done they come with lower torque box reinforcements, the subframes, and braces for under your seats. both are awesome but the steeda is just a little easier to install.
            • Roast'em
              has posted this
              • 5496
              Just get some easy $99 ones Tim.
              • bullitt
                • 1313
                My MM ones were 79 bux shipped. I POR-15'ed them. Then get carnutz to weld them up for cheap. Nice job too.
                • bad-speller
                  • Feb 2004
                  • 943
                  If your going do it half assed, buy a piece of angle iron and weld it in, otherwise do it right and get full length subframe connectors. (yes, the more expensive ones)
                  Steeda copied MM's old design connectors, go with the MM's new XL's which are half again stiffer than their old full length connectors.
                  Brian
                  08 Corvette Z06
                  00 Mustang Cobra R
                  09 BMW X3
                  • bullitt
                    • 1313
                    Man, if I would've known my subs were half assed I woulda just knocked down some stop signs and welded those bad boys up.
                    jk
                    Standard lengths are fine for a street/drag race application. In a vert I may go for the full lengths, but then again I'd never own a vert.
                    • Video_Master
                      Kickin it Hybrid Style
                      • 10524
                      This is the setup I am ordering in 1 week. The outer ones which connect the ront to the back are weld in and the center section is a bolt in to the outer sections. Then I can get a torque arm that mounts to the center section fron the 9" rear.
                      • bad-speller
                        • Feb 2004
                        • 943
                        Buy some angle iron.
                        08 Corvette Z06
                        00 Mustang Cobra R
                        09 BMW X3
                        • bullitt
                          • 1313
                          Have fun disconnecting your exhaust when you need to.
                          • StangerJon
                            esse jay
                            • 16655
                            I like the ultra beefy kenny brown ones kickassflash has. get him to post a pics of his.
                              where can i order my subframes from then? i was looking into the full lengths from MM.
