How to Advance Timing
  • junno1616
    ALL THROTTLE NO BOTTLE
    • 76
    I have the timing gun, i was just wondering how to advance my timing to 14degrees, step by step. I'm a newbie to this, thanks
    If this helps:
    87 GT MassAir Converted
    DSS Pro Bullet 306
    Accel Billitech Distributor
    Stock ignition
    Chuck Norris doesn't go hunting....Chuck Norris goes killing!
    2003 Nissan 350Z Black 287HP
    87 Fobra 321HP
    DSS 306 Pro Bullet
    Mass-Air Converted
    Ported Cobra Upper&Lower
    24# Injectors
    17x9 4Lug Cobra R's
    Hook up timing light on spark plug end as close to the spark plug as possible (within a foot) making sure the arrow is pointed toward the spark plug. Hook up positive and negative leads. Take a tire crayon and mark 14 deg. BTDC on the harmonic balancer. Start car. Pull out the small spout connector in the plug. It is a 2? wire connector close to the distributor. It looks like a very small module and don't lose it. Loosen distributor hold down bolt. Find timing mark while aiming light at mark turn distributor until pointer is pointed at 14 deg. BTDC. Tighten down distributor hold down bolt. Re-check timing. If still at 14 BTDC re-connect spout connector. Unhook positive and negative leads on timing light and spark plug lead. Proceed to piss pound car to see if it is any faster.
    • junno1616
      • 76
      Thank you, makes sense now
      87 Fobra 321HP
      DSS 306 Pro Bullet
      Mass-Air Converted
      24# Injectors
      17x9 4Lug Cobra R's
        It's easy. Bring it down to Porky's and there are plenty of people that can help do it in the parking lot. Just mark the balancer prior to trying to time it or it's a Pain in the Arss
