optima batterys are junk.
  • crzy88lx
    I Rock Catholic Girls
    • 3561
    i bought an optima from my work and it would not hold a charge at all. i had it on the charger on 12 amps for 3 days straight and it was still drawing 5 amps. i dont understand. everyone i know who has the battery loves it.
    Total happiness is being stroked and blown at the same time
    https://www.facebook.com/IBuiltMine
    Which Optima? I know a lot of people that have them and love them.
    • crzy88lx
      • 3561
      i had the red top. i know, poeple love them, maybe i just had a bad one. either way, i will not buy another one. i just bought a good interstate with 1000 cranking amps and a 85 month warrenty. it was cheaper and the warrenty was almost as long as the optima's
        dont base your discision off one battery.
        i have one and its great. never gave me a single problem. i have a yellow top.
          I swear by Optima batteries. But furthermore, I find it safer to have a battery without acid sloshing all over when taking corners on the course and such. Having a problem with an Optima must be a rare event indeed, sorry to hear you did not have good luck with one. You should have tried another one though, there will always be defects in any sort of manufacturing process.
          "Mustangs are pieces of shit. I went to test drive one, and it didn't even start. I just went over to the other lot and bought myself a Honda, gets great gas mileage and the car has a lot of power!"
          • Shadowgray03
            Snake Charmer
            • 1141
            Ive got one in my truck and its never let me down.
            2003 shadow gray cobra
            VT Stroked, Crower cammed and KB Topped
              Remove head from ass, press in brake and clutch, then turn key.
              • Mustangmatt
                The bobs...
                • 10806
                you sure do have a lot to gripe about today
                • MontiMach
                  Wanderer
                  • 862
                  I have a dead red-top in the garage as well.
                  Didn't last a single winter.
                  BSM Flunkee
                    My red top outcranks any other battery that fits in my tray. It will hold a charge all winter long, even hooked up. It is 6 years old.
                    • Turbo302
                      • 1528
                      Optimas are very sensitive to their charge rate. Where I work, I always get free Optimas in on core exchange (we sell alot to a construction company, and they replace all batteries every 3 years regardless). I always charge them at a 2amp rate for a couple days, and they always come to life. If you fast charge them, they will burn up. Part of the warranty determination is to weigh the batteries. If they have been cooked (fast charged), they will weigh less than a good one.
                      Tim
                      1988 5.0 Notchback
                      • Xtort
                        • 6968
                        I currently have a yellow top that is my second Optima going on 6 years, never had a problem. If I remember correctly I had a 900cca redtop for 3 years before my 210 amp alternator that was failing took it out and I got my yellow top.
                        At this point I will never buy anything but Optimas!
                        http://youtu.be/GTQnarzmTOc
                          Not to insult your intelligence, both of the guys having problems with the optima's, but are you sure the battery is the culprit? I'd say 50% of the batteries that people bring in and say are shot, there's nothing wrong with. They usually find something else is the problem. A lot of the time it's just a bad connection or a battery cable. I'm not saying this is the case but I'd have the batteries tested with a really good tester. Ours is $1,000 and it tests the conductance of the plates in the battery.
                          • Matt D.
                            I like turtles.
                            • 345
                            Of everyone I know who has had a bad Optima (not many bad ones of all the ones out there) they have always been the result of improper care.
                            2003 Mitsubishi Lancer Evolution VIII
                            • -D
                              eat shit..eat my shit
                              • 2708
                              I had a bad red top, and I know it was the battery, because I had it tested 2 times, put in a new battery, havent had a problem since...red tops suck....yellow might be ok though. seems more people have problems with the red tops than the yellows.
