tranmition problem
  • jjhirsch
    hirsch
    • 3776
    tranmition problem
    ok it drive find it shift fine from a dig. the only thing is when i am going about 60-70 and i hit it all the way down it reves up to hit 2nd and some times it redlines befor it ceatches (maby i never noticed it)
    then also how do u know when ur u joints are going out because i feel a little clunk when i tap the gas going 35 or so like the trany to the rear is louse.
  • NAZISALEEN
    Afro Samurai
    • 12235
    IS your AOD stock?? They are natorious for pressure problems. Did you mean to say when you step on it at 60 or 70 it has a hard time going into drive or (3rd) From overdrive??
    • Bill M
      fastest inline head SB in RS/N
      • 3404
      My C4 did similar things, turned out to be second gear band was gone and ate the drum too
      "Uh oh, that ain't good!"
      www.meanstreetperformance.com
        Holy grammar!
        • Emart
          Made
          • 6019
          Originally posted by SVT-5LITER
          Holy grammar!
          • jjhirsch
            hirsch
            • 3776
            ok when i hit the gas at 60-70 it goes in the 2nd and usly grabs at 4500rpm but some time it redlines befor it cetches.
            • NAZISALEEN
              Afro Samurai
              • 12235
              SO it goes from overdrive to second?????
                If it's going from OD to 2nd, thats bad.
                • Video_Master
                  Kickin it Hybrid Style
                  • 10524
                  • I Tried
                    Pull my Winch Line 4 Me.
                    • 6103
                    OD band in hanging on and then causing a slip time for a o-haul
                    • jjhirsch
                      hirsch
                      • 3776
                      what ya mean though? why would it go for 3rd when it can get 2nd?
                      if it goes od to 3rd it is really slow.
                      • NAZISALEEN
                        Afro Samurai
                        • 12235
                        OMG
                        Get a new tranny. Yours is probably smoked.
                          JJ stop manually shifting it...asap.
                            JJ you aren't still manually shifting that thing, are you?
                            • SuperHO
                              Shits Weak......
                              • 4609
                              manully shifting an auto thats not gooooooood
                              Outta Control Racing Ooo
                              HTM high compression 306 319 Hp 342 Tq
                              Stock headed 302 281HP/322TQ HTM E-85 Tune
                              http://www.hitechmotorsport.com/
