MT drag radial review
    26x9.50x15 drag radials (I think the smallest ones they make) I cut a 1.53 60 ft. Anyone interested in them I highly recommend them.
  • LX Sport
    Murdered
    • 15323
    kind of a weak review. what was your best pass?
      Hmmm...maybe thats what I need...
      • TitaniumGT
        • 11042
        How are they on the Street?
        446RWHP and 585RWT
        Vortech S-trim
        346rwhp and 314rwtrq
          I did the 30 mile road cruise with them. They are fine. I don't know how they are in the rain though. I also don't think they are going to wear very good but you're going to get that when they are this soft. Best pass was an 11.55 @ 112.60 on a 125 shot.
          • 86convert
            • 530
            I just got some 26x11.50x16 et streets and I think those are pretty good. I LOVED how they hooked at the track.
              What was your best 60 ft. on them? I had to run a drag radial in Wild Street so I went with the MT's.
                Nick, are you still running your tremec or are you using the c4?
                  His Tremec has been gone for a long time now
                    Matt seems to be correct, although I don't know who his source is.
                    No, it was weird. With the converter I have I was leaving at idle. I was also hitting the nitrous out of the hole. The converter was flashing high enough to be safe.
                    I put together a C4 myself. I used alto red race clutches and bands. My best motor pass was a 12.43 @ 106 and the year prior it was a 13.00 @ 106. I did do some extensive rear suspension mods also.
                    • 351capri
                      64 fairlane someday
                      • 14584
                      Does your C4 leak fluid? Mine does Could it be because the i can wiggle the converter when its fully engaged in the tranny? It has a brand new bushing and seal in it.
                      ET streets are scary in the rain, i have them but have never got caught in the rain (yet), my brother has them on his ride and he had to slow way down to about 30 MPH.
                      • 86convert
                        • 530
                        My best 60 ft is only a 1.873 but you have to realize that I have only had the car to the track once and I still don't know how to launch this car. Every time i launched hard the motor boged down. I think if I launched some where around 4500 rpm I should get rid of the bog.
                          yeah, that should take of it, it also depends on what you have for rear suspension.
                          Capri:
                          My transmission doesn't leak. You may need a bigger cooler. I am not sure. Have you tried replacing the seal? Maybe it got crooked when installing it? If I remember right I could wiggle the converter just a little when I put it in. Is it seated fully? It would probably have to be or you would have lunched the trans already. I'd try putting a new seal in it. Make sure you get the front pump clean where the seal rides. See how pitted it is. Do you have a tranny temp gauge? How hot does it get? Nick
                          • 351capri
                            64 fairlane someday
                            • 14584
                            Capri:
                            I have a good sized cooler on it now, i have placed my had on it after driving it and its not hot by any means, i can put my hand on it without a problem.
                            The seal has been replaced a few times, i had a mechanic put the bushing and seal in the last time, the seal is even a ford brand seal, i watched him install it, its straight.
                            I made sure the converter was fully seated, cause when i tightened the nuts of the converter through the flex plate holes, it pulled the converter to it, so there is enough clearance there.
                            I dont have a tranny temp gauge, maybe it wouldnt be a bad idea.
                            Tony.
                              Yeah, I don't know. The only other thing is to really look at the front pump. If it is really scored or has dings in it where the seal rides maybe try a different pump. Do you know if it's leaking between the outer lip and the pump or is it leaking between the rubber seal part and the torque converter?
