I have a dilema. I have been hearing mixed reviews about how and what to do, so if you know, please enlighten me. I bought a complete polyurethane cushing kit from TurboX2 (thanks dude
). Since I have to take the control arms off of the rear, I was going to buy some for cheap, torch out the old bushings and box the upper and lower control arms, paint them, and install my new bushings. That way, I can take my time welding and painting the arms when I finish. I have heard the following....
1. Do not run poly bushing in the control arms, it's hard on the torque boxes.
2. Hard poly urethane bushings on both ends of your controls arms is BAD for autox. The rear end can not move around as it is forced through corners etc. This is bad. Can cause snap oversteer and other unwanted characteristics.
3. You should run a stock style rubber bushing at least in one end of the uppers to prevent binding while it travels through its up and down extremes.
4. poly bushings in the lowers on both ends but rubber in both ends of the uppers.
I do not really want to spend the money on new control arms since boxing them is free. I figure it's something to do to add strength while they are out. So what is the best thing to do? Should I box Both the upper and lower arms, or just the lowers. I do not want to waste my time boxing the uppers if it is not worth it. Is it a bad idea to run poly bushings in all 4 arms? I am going to box the lowers for sure, and probably the uppers if it is necessary, which I do not see how it can hurt.
). Since I have to take the control arms off of the rear, I was going to buy some for cheap, torch out the old bushings and box the upper and lower control arms, paint them, and install my new bushings. That way, I can take my time welding and painting the arms when I finish. I have heard the following....1. Do not run poly bushing in the control arms, it's hard on the torque boxes.
