Anyone in mankato with a set of torches
  • jp67stang
    bet ya cant do it like me
    • 1820
    Wheel bearing on the truck went to shit need to torch off two striped bolts. Not sure i can drive the truck as its that bad, could pick up and willing to pay for use.
    Let me know thanks 651 245 9904 john.
    mustangs are for fags
  • xjfish
    siiiiiiick!
    • 7357
    If you are trying to remove a hub and the bolt heads are rounded off I've had some luck with Irwin "bolt grip" sockets used with a cheap small propane torch. Just a thought, I'd bum you a torch if I was closer, goodluck.
    1987 Oldsmobile Cutlass Ciera
    • jp67stang
      • 1820
      Ya my father got some tools think its bolt grips from the neighbor and is bringing them down tomorrow hope it works, bearings are so bad the actual bearings started falling out found one lodged in the rotor guess 250k is the limit.
