Fuel pressure question
  • Top Down 352 Stroker
    • Jan 2012
    • 527
    Ok on my 88 fox 352 stroker, 24 lb injectors 80 mm mass air, 75 mm t body. What should I run for fuel pressure about? Having problems with runnability. Pretty sure its not getting enough fuel now. It has a brand new 255 walbro in it. Anyone have any info?
    • Jan 2012
    • 527
    Does 38 sound right?
    • Odrapnew
      Everyone likes being blown.
      • 2880
      Is it running bad all the time? A factory pressure regulator is 39psi with the vacuum line off. Is your reading with the line off?
        • Jan 2012
        • 527
        Um not sure, my buddy was doing the checking. We put my aeromotive adjustable regulator on last night. It runs fine when cold most of the time but when warms up starts popping back through the intake and sometimes starts to ping. Havent tried to see if anything has changed yet. Mad box and dist. will be going in it this weekend too. Oh ya at higher rpms it comes out of the crappy running and seems to run better.
