1993 cobra: horn, radio, and turn signal not working
  • ICULKN2
    • 191
    Drove my car this morning and got to my first turn, turned my blinker on and it didn't work. Turned around and got home and found out my radio and horn didn't work either. The hazards work just no blinkers. Anybody have any trouble shooting I can go through to figure out what it could be?
    Thanks Neil.
    Dart block 331, Brodix m2 ported heads, victor intake, and many more things to come.
    http://www.youtube.com/watch?v=ScBQVipNTlk
    www.dentkraftpdr.com
  • Darkness
    Iron chef of pounding vaj
    • 7595
    Sounds like a fuse.
    • ICULKN2
      • 191
      Sorry. Forgot to mention I checked all fuses and they were all good.
        Double check the fuses again
        • ICULKN2
          • 191
          Rechecked fuses. Still all good.
          • Darkness
            • 7595
            Pull radio and see if its getting power.
            • Odrapnew
              Everyone likes being blown.
              • 2880
              Could it be a fuseable link? Do power windows work?
              Go to link below and see if you can find the correct wiring diagram. Might be able to find something.
              Mustang FAQ - Mustang Wiring, Air Bag, ABS, Engine Home Page
              • CS
                • Apr 2010
                • 582
                maybe your blinker arm is out and causing a power issue, try disconnecting the arm and see if the other items start working. Usually those arms will go bad after a while that is a common problem
                • ICULKN2
                  • 191
                  After some very detailed searching I found a relay for my blinkers in my glovebox. Plugged it back in and it works. As for the radio, I found a plug that came loose and after I plugged back in, that works. Now I just have to get the horn working. Anyone know where the relay is for that? Fuse still good.
                    Since it's so accessible, check power at horn
                      Fuse is #16, 20a
                      • ICULKN2
                        • 191
                        Thank you everyone that gave advice. I really appreciate it! I found that my horn relay is missing. It is a brown plug. Thank you Fernanernie. So I ordered a new one and everything works now. Thanks again for the help.
