fitting a 275/60/15
  • 5.0stang85
    Hater's be hatin'
    • 7065
    fitting a 275/60/15
    how much have people had to beat the inner fenders in to get them to fit?
    Cooter's Coatings
    Hudson WI
  • Paul Revere
    Classier than most ...
    • 12706
    Like you'll ever need to use a tire of that size.
    • Beavnasty
      • Mar 2010
      • 1336
      This.
      Originally posted by NOTNSS
      I masturbate while watching the new Oprah network, TOTALLY WORTH IT!!!!!
      07' 300 SRT8 - Tuned by some Kyle guy 382whp 392wtq
        depends on the wheel you're running. taking the the quad shocks off or flipping them is key, and you might have to just have to roll the fender lips.
        i'm sure he can still spin 275 tires, it's not that big of a size, i don't see what the big deal is.
        • 5.0stang85
          Hater's be hatin'
          • 7065
          Have 4.30 gears - it'll spin threw 2nd from a 5mph roll with the 27/10.50 ET Streets I have now- with the tires cold it'll spin half way through 3rd
          I have a 15x8 Weld Prostar w/ 5.5"BS have a 3/16" spacer on them also right now as they used to rub on the inner fender
          No quads (83 didn't have them)
          Outer lips are rolled - the inner fender is beat in a bit
          Height isn't the issue for my car after dropping 75lbs or so from the inside of the car it's the width- Discount tires website says the 275's are 3/4" wider than the 27's(255/60)-
          Cooter's Coatings
          Hudson WI
          • octanehuffer
            • 5265
            Mini tub FTW
              Between your wheels, spacers, rolled fenders and lack of quad shocks, they should fit fine.
              • 5.0stang85
                Hater's be hatin'
                • 7065
                Mini tub FTW
                THIS is what I don't want to do- also REALLY not wanting to take a sledge hammer to the inner fenders to get the fenders flush with the frame rails
                Cooter's Coatings
                Hudson WI
                • 94fobrah
                  2012 RSN #3
                  • 8820
                  They will fit no problem, minor pounding is all that's needed
                  90 LX 445CI N/A SBF
                  Built By Dave Senderhauf JR
                  • 5.0stang85
                    Hater's be hatin'
                    • 7065
                    LOL I've already done that- you have any pics of your car with them on it?
                    Cooter's Coatings
                    Hudson WI
                    • 94fobrah
                      2012 RSN #3
                      • 8820
                      Here it's on 28-11.5-15's quick time pros which are a tad bigger than my 275 Hossier's were.
                      90 LX 445CI N/A SBF
                        Much like your mother
                        ZING!
                        With that much pounded out, no quads, and that wheel spacing setup, they will fit.
                        • 5.0stang85
                          Hater's be hatin'
                          • 7065
                          We will see - I ended up getting a pair off Nitto's on discounttire.com cause going through a local source I'd have to have my car on stands for a week or so while the tires got swapped out
                          I bet my 27's aren't 1/2" from the inner fender now..
                          Cooter's Coatings
                          Hudson WI
                          • johnnyb
                            merc power
                            • Jun 2009
                            • 737
                            I have 275/60 on my car with a rim with 5.5 back spacing.
                            Only had to do the bottom of the wheelwells.
                            Turbo chevy 383 power in the merc.
                            • KrisR
                              KNT-SHO
                              • 12737
                              Really? I'm a little sick of the Hate On Zac posts. Anyone else?
