Electrical Question
  • Stroked 94 GT
    Formerly 99Z-28
    • 511
    Electrical Question
    Anyone on here know anything about Bronco tail lights?? I have a 79 Bronco and the passenger side brake light wont come one when I push the brake pedal. I replaced the bulbs, so I know they're not burnt out, so I'm assuming it is some bad wires. I read in another forum that TRDon knows about electrical stuff, so if you wanna chime in or meet up sometime and take a look at it let me know, I'd appreciate it, anyone else who could help me out I would also appreciate it. thanks.
    Cody
    He knows electrical in terms of houses I believe.
    I'd check your grounds.
    • Shadowgray03
      Snake Charmer
      • 1141
      See if you can get the lead of a meter in on the back side of the actual socket and have someone press the pedel and see if their is voltage. It could be that the contacts in the socket are corroded or bad. If thats not it then you will need to round up some wiring diagrams for the truck and start checking for voltages where you can to determine which section of wire is failing and then splice around the failure.
      2003 shadow gray cobra
      VT Stroked, Crower cammed and KB Topped
      • ford_fixer
        • 597
        Does the blinker on that side work?
        If the blinker on that side works, most likely the problem is in the turn signal switch. T/S and brake light are same wires and element in the bulb..
        Democracy is two wolves and a sheep voting on what to have for dinner. Liberty is a sheep with a gun who disagrees with the decision.
          You have very good leads right here. I am a electrician, more for commercial and residential than cars, just so you know. Check for voltage (IF YOU HAVE A LIGHT OR METER) and the signal. If everything checks out, post up and we can try to go from there. If you dont have a meter, we can arrange something.
          • -D
            eat shit..eat my shit
            • 2708
            Roast em had that problem on his car, he played with something behind the brake pedal and it works now...could pm him and give that a try.
            • eatonranger
              3 LITRE MAFIA
              • Oct 2004
              • 260
              I would start by checking the grounds. Does the drivers side brake light and turn signal work? Do you know if the brake light switch is clicking on and off? If the left turn signal comes on then the switch is working.
              02 ZX2 5 spd stock Bright Atlantic Blue
              92 Ranger 3.0L 5spd
              M90, Intercooled, 7-8psi, 70MM TB
              JBA Headers, 4/4 drop on 98 Cobra rims
              220rwhp 260 rwtq as of 8-20-06
              Expo rearend w/3.73s LS and Discs
              www.cardomain.com/memberpage/837330/1
