So I noticed my engine had an odd vibration after putting it back together after pulling the blower off to fix an oil leak. I kept thinking it was a cylinder missing. Check the plugs and they all looked fine. Decided to take a peak under the hood when it was running and noticed the crank pulley wobbling all over the place. So I pulled the blower pulley off and put on a stock one, same thing. Pull the balancer off and this is what I found. Does that look like a sheared key, or just a messed up balancer? I'm pretty sure a small piece of the key fell out when I pulled the balancer off. I was planning on bringing the car up to storage next weekend, now I'm not sure what I'm going to do.
This is a Romac balancer. That little piece came out when I pulled the balancer off. The rest of the key is still there, but it's definitely not as tall as it was. The crank snout doesn't look too bad. There are a few little grooves where some material was built up from something(not sure what). I think the balancer inner surface looks worse than it is because most of that is a thin layer of rust. I decided to grab a factory balancer from Napa and put that on. I was surprised how easily the balancer went on, I was able to wiggle it onto the crank(and line it up with the key). I was able to push the balancer all the way onto the crank, is that normal? It wasn't loose, but I was able to get it all the way on. I suppose the slight layer of rust came from the crank and was enough to give a slight clearance. Well, the wobble is gone, go figure. I just put on a factory crank pulley so I can drive it up to storage next weekend and I'll pull it apart in the spring.
