Car diesel's a littlle when hot.
  • 94fobrah
    2012 RSN #3
    • 8820
    I have only noticed it once but after a cruise when the car is well up to temp and I go to shut it off it diesels a little bit.
    Not bad but I don't want it to do it at all, I know its nothing new but whats the cause of it?
    90 LX 445CI N/A SBF
    Built By Dave Senderhauf JR
  • iamtheshaner
    • 3566
    If it runs on, it's getting fuel somehow. Carburated = you have carbon hotspots. EFI = you likely have leaking injectors
      It must make pretty good torque if its dieseling
      • Max Power
        • 13086
        Fuel and air. Usually the throttle is cracked as well. On carbed motors with lots of cam, the throttle is cracked so it will idle, so it happens on fresh motors with no carbon.
        Simple fix? Use the drivetrain to stop it. On an automatic, usually the resistance of the converter is enough. On a stick, just engage the clutch a little with the brakes on.
        • 94fobrah
          2012 RSN #3
          • 8820
          I suppose I could just kill it when im still in reverse, then just put it in park after its off.
          90 LX 445CI N/A SBF
            I thought it had something to do with octane/timing in some situations. Not sure on your compression though.
            • 351capri
              64 fairlane someday
              • 14584
              Mine does that if i run 89 octane, and cures it if i run 92.
              • 94fobrah
                2012 RSN #3
                • 8820
                It's a pump gas 438ci with 10.5 to 1.
                90 LX 445CI N/A SBF
                • 94fobrah
                  2012 RSN #3
                  • 8820
                  Interesting
                  90 LX 445CI N/A SBF
                    too much timing/?
                      On my small block, when it gets hot, I'll diesel sometimes too. Like stated above, I can just shut it off while in drive and it won't do it. I'd like it to stop though.
                      • shagwag
                        In Memory of Bill J. Gefre
                        • 4234
                        Where are you buying your gas and what is your timing at? Non ox is a good idea in that motor if you can find it. Did you dyno with strait pump gas?
                        5.38@130
                        8.40@161
                        Originally posted by sinSStr
                        Originally posted by crazy
                        i am the one that cant spell
                        www.tntraceshop.com
                        • 94fobrah
                          2012 RSN #3
                          • 8820
                          All I know is it was ran on the dyno with pump gas, I put 93 from bp in it the first time and the second time I put non oxy from Bills.
                          It has only done it with the non oxy from bills, the timing is set right at where it was on the dyno. I'll time it tomorrow and see exactly what its at.
                          90 LX 445CI N/A SBF
                          • octanehuffer
                            • 5265
                            The very, very high hp cars are getting more power with oxygenated fuel. Cool story. My uncle builds very hi hp circle track engines and will net an extra 18 hp using the oxy vs. non. I am talking about 830hp natural aspirated 350's.
                            I have a dieseling problem this year too. Last year the engine was around 9.0:1, this years engine is at 11.0:1. It has dieseled every time hot. I initially thought timing, but changing has never helped. I ruled it to be the carb. I had turn up curb idle on the bitch. The only thing that changed from last years engine was the block and raised compression. All other parts were perfect. Something I live with.
                            • taank
                              • 10278
                              mine does it too. too much on base idle screw. need a looser converter
                              Jake H.
