Dyno Day 351c...any predictions???
  • lazermule
    • Nov 2010
    • 163
    Headed for the dyno this Friday with my 351C and looking for predictions. A couple of you guys were pretty close on predicting my 440 Mopar so I figured I'd throw this one up here for some fun.
    Here are the spec's:
    351C .030
    12:1 TRW dome forged slugs
    Actual measured CR is 10.45:1
    US open chamber 2v heads ported (255 cfm int / 213 cfm exh flow)
    Full roller valvetrain
    Comp roller custom grind .693 / .674, Dur @ .050 258/260, adv dur 291/293, lobe sep 108
    1 7/8 headman hustler headers
    Weiand X-Cellerator (single plane) ported and port matched
    FAST EFI setup (1000 cfm)
    DUI HEI ignition
    Windage tray installed
    Fully balanced rotating assembly and ARP rod bolts
    7000 rpm redline
    What are your predictions???
    LM
  • octanehuffer
    • 5265
    What size injector?
      470hp
      • Paul Revere
        Classier than most ...
        • 12706
        Very interested to here this outcome.
          Is this engine, or RWHP?
          • chevyguy15
            • Jan 2011
            • 732
            441 at the crank.
            • chevyguy15
              • Jan 2011
              • 732
              What size injector?
              i bet he has the fast easy efi
              • Hack
                • 1415
                350-390 at the crank I'm thinking.
                2017 Mustang GT PP
                1986 Porsche 944
                • RegalX
                  Model A Mafia
                  • 3154
                  483hp at the crank
                  • octanehuffer
                    • 5265
                      457/486 at the crank.
                      • lazermule
                        • Nov 2010
                        • 163
                        What size injector?
                        Modified 90 lb injectors. The efi system will supply up to 650 HP. I will be making a few pulls with a carb as well (850 CFM) just to validate the EFI setup is worth the extra cost.
                        Looking for estimates on crank HP.
                        LM
                          LM
                          • mark_eych
                            • 1442
                              408 hp 423 tq
