anyone wanna make some cash?
  • siberianmist
    • 2681
    1) 01 navigator needs new compressor for air suspension. i guess the failing compressor is causing the relay to burn out? the relay burned out once and it was replaced but its going out again. anyone know how to install one of these compressors who could also get a new one? how much?
    2) 06 mustang needs oil change and new front brakes put on. i have oil, filter, rotors, calipers with pads already in them and lines connected to the calipers. kind of a bitch to get under since it is lowered. $60 obo if anyone near st paul can do this...
    Why are you replacing your calipers?
    • 98RioRedGT
      • 1966
      the compressors are spendy. did you have this at Inver Grove Ford today? a guy at my work was working on one of these today with the same problem. there is an updated compressor out for these with a new style bracket that helps eliminate compressor noise fyi.
      -1969 Mach1 428 SCJ project
      • MINNESOTA 5.0
        I FIX OTHER PEOPLES FUCK UPS
        • 2852
        just did this for my neighbor. air pump seized.
        89' NOTCH- 327 TURBO, C4
        • merkerguitars
          FML
          • Jun 2007
          • 665
          Can't figure out how to push the pistons back in ?
          • siberianmist
            • 2681
            yes it was at inver grove today. they replaced the part under warranty but they want my soul to put a new compressor in so id like to get it taken care of elsewhere...
            • siberianmist
              • 2681
              im replacing the calipers because i bought a set of new take off brakes from a gt. might as well use these new ones with the pads already installed.. nothing wrong with the ones i have on currently but the takeoffs already have the brackets and pads installed + less miles
              • taank
                • 10278
                Run the brakes you have.
                Jake H.
                • taank
                  • 10278
                  Me you and notch should do lunch
                  Jake H.
                  • siberianmist
                    • 2681
                    ok that arnott website has em for $200... is the install as easy as it sounds... someone must want to do this?
                    Instructions
                    REMOVAL & INSTALLATION
                    Remove the windshield washer reservoir.
                    WARNING
                    Before repairing any air suspension components, disconnect power to the system by turning off the air suspension switch located in the passenger side kick panel area to prevent vehicle damage or personal injury.
                    Turn the air suspension switch to the OFF position.
                    Disconnect the air line tube to the air compressor drier by depressing the red ring. Remove the air line.
                    Detach the air compressor electrical connector.
                    Remove the air compressor bracket bolts.
                    Remove the air compressor.
                    To install:
                    When installing the air lines make sure the white air line is fully inserted into the fitting for correct installation.
                    The installation is the reverse of the removal.
                      I'd throw a new drier in there while you're at it since they are usually forgotten about.
                      • Paul Revere
                        Classier than most ...
                        • 12706
                        Why can't you? Too scared to hurt your penis fingers?
                          Whities anyone?
                          • siberianmist
                            • 2681
                            it would take me a day. i will if i have to but id rather pay someone else to do it promptly. im very impatient, its not worth the frustration.
                            as far as the stang. its a bitch to get under. i have to drive it on top of 2x4's, then jack it up, jack stands were stolen over the winter, dont feel like sliding around on my back, yeah. oil filter is in a decent location though...
                            • Paul Revere
                              • 12706
                              Man card revoked.
