head studs
  • 5.0stang85
    Hater's be hatin'
    • 7065
    head studs
    thread sealant OR oil to install??
    I have used motor oil just fine but wondering while I have thread sealant handy....
    Cooter's Coatings
    Hudson WI
    teflon tape.
    • 5.0stang85
      Hater's be hatin'
      • 7065
      Originally posted by 2 beer View Post
      teflon tape.
      I have the liquid equivalent.. ok I'll use it instead of the oil
      Cooter's Coatings
      Hudson WI
        the tape works the best. its like $.99 thats what I use.
        • Turbo302
          • 1528
          Use thread sealer only on the threads going into the block where waterjackets are. Use 30wt with one set of torque specs or ARP moly lube with the other specs on the studs where the nuts/washers go.
          It should be in on the spec sheet in the box, or lookup ARP's site
          1988 5.0 Notchback
            It should be in on the spec sheet in the box, or lookup APR's site
            hogwash. teflon tape on all the studs. both ends.
            • Turbo302
              • 1528
              1988 5.0 Notchback
                dipshit, in all honesty turbo302guy is right. read the directions. you are putting together an engine not a god damn lego set. READ THE DIRECTIONS.
                • theduckylittle
                  Duck uber Alles
                  • 5435
                  Directions for all my head studs said moly all around... so ... this advice would be more than correct.
                  • MINNESOTA 5.0
                    I FIX OTHER PEOPLES FUCK UPS
                    • 2852
                    COPPER SEAL RTV.
                    dont use anything else.
                    89' NOTCH- 327 TURBO, C4
                    • 5.0stang85
                      Hater's be hatin'
                      • 7065
                      I did this
                      Cooter's Coatings
                      Hudson WI
                        Originally posted by MINNESOTA 5.0 View Post
                        COPPER SEAL RTV.
                        I prefer Ultra black RTV, superior fluid resistance. To each his own.
                        • 5.0stang85
                          Hater's be hatin'
                          • 7065
                          lock tite was on them at one point
                          Cooter's Coatings
                          Hudson WI
                            COPPER SEAL RTV.
                            That its what I use
                              That its what I use
                              Engrish.
