little help
  • jjhirsch
    hirsch
    • 3776
    little help
    ok my gound wire has a bad conection so what i did was unconected it and put a wire from the (-) of battery to the block. it runs and starts good but would i still be able to huck the (-) from the starter to the battery to make a better conection? or will it mess the circite up?
  • bigblockpaul
    i live my life a quarter mile
    • 4137
    what
    The wire going to the starter is your positive cable...Not ground...Most negative cables go to the moter block.....You should clean both ends of your neg cable put back on and then buy another with holes in both ends and put one end on the frame and the other end to the block....Cant have enough ground on the mustangs....Paul
    • jjhirsch
      hirsch
      • 3776
      oh ok i thought my stock ground went to starter. so i can have both the stock and another ground that i made?
        yeah two grounds are better than one. Just make sure to use some good thick wire...not speaker wire.
          Welding cable works good. Very flexable. 2 or 1 awg is what I would use.
            Yeah..Welding cable can be bought at any welding supply shop Justin. It's usually cheaper than a lot of other places too.
            • jjhirsch
              hirsch
              • 3776
              well i got my stock ground hucked up with my 4 gage amp wire ground to the intake manafold
