e85 or pump gas?
  • chicostang95
    • 1076
    e85 or pump gas?
    I need your opinion people. I should be getting my car back from Richard over at msp within a couple of weeks and all I would have left to buy would be injectors and computer. So I'm still deciding on getting the 160lbs injectors and run e85 or I should not?? Any inputs will be appreciated ! thanks!! Oh and this is going to be a street car until I decide to put a cage in it ( not anytime soon).
  • Mullet Tuner
    • 15906
    Details on setup? Do you have the rest of the fuel system to handle the demands of E85?
    Originally posted by Gerald
    • Paul Revere
      Classier than most ...
      • 12706
      I am with stupid ^
        Nice sn
          Oh and no cage? Why was it at meanstreet?
            I'm guessing rear axle or hotside.
                If this is a track car only and you are looking to maximize power, then e85 may be a good alternative. If you'll be driving this one the street, forgot about it. Run gasoline.
                  Yes screw e85!
                        • Paul Revere
                          • 12706
                          Yes screw e85!
                          I think what he meant to say is that if you have a boosted car or run high compression than E85 would be a good alternative to race gas as it is cheaper, burns cooler and therefore has less detonation.
                          The main concern with running it is providing for the larger fuel demand and knowing that the mileage in comparison to pump gas is much worse. I think RivKid said some 22%
                          • shagwag
                            In Memory of Bill J. Gefre
                            • 4234
                            You will need a fuel system that will support 30% more hp than you plan on making to run e85. Im not generally an advocate if e85 but in a turbo car i think its not a bad idea. More exhaust volume and the motor should run cooler. Like already stated you will get worse fuel economy, (who cares) and early and late in the season its not e85 but e70. MY impute.
                            5.38@130
                            8.40@161
                            Originally posted by sinSStr
                            Originally posted by crazy
                            i am the one that cant spell
                            www.tntraceshop.com
                            • chicostang95
                              • 1076
                              putting new driveshaft, putting new torque converter, front coilovers, exhaust and making the new turbo fit.
