6.0 Diesel just dies
  • 2000 roush
    Damn it
    • 7216
    At a stop light today my 03 Dually just died, no warning nothing just died then I restarted it just fine and parked and was ideling and died again. restarted fine, drove fine and no CEL light. Anyone got any ideas?
    slower than a dead snail
  • svonasek
    • 1641
    Cam position sensor. It'll shut off like you turned the key off. No warning. No rough running just dead
    • 2000 roush
      Damn it
      • 7216
      Is there any way to check that? How hard top replace?
      • iamtheshaner
        • 3566
        This or FICM harness. Try pushing on the wiring harness that goes from the metal box on the driver's side of the motor while the engine is running and see if it stalls. That wiring harness had rubbing issues nearly all years and it controls the fuel injectors. The harness rubs on the engine components so usually it will hiccup better if you push rather than pull on the harness.
        • 2000 roush
          Damn it
          • 7216
          Thanks Ill check that our too!
          • svonasek
            • 1641
            I'm not sure if the 6.0 litre is the same as me 7.3. On my 7.3 it takes about 10 minutes to replace it max. There's one bolt that holds it in.
            I believe they were around $30. I carry a spare with me. It seems like I replace it every couple of years now.
            • engnerdan
              Welds Things
              • 1135
              Also only buy a factory Motorcraft cam position sensor. When I bought my 7.3 it had a brand new one from the parts store. It was not a week later and I was having problems. Replaced it with a motorcraft part (all of $15 with the TCS discount) and no problems since.
              -Dan
              DW Metalworks LLC
              Aluminum, Stainless, steel welding
              www.dwmetalworks.com
              • 2000 roush
                Damn it
                • 7216
                -Dan
                Where did you buy yours, Apple Valley Ford?
                • 1 Bad Z
                  • 87
                  Make sure you or someone else didnt put regular gas in the tank. I know a guy that had the simular problems and he filled it up with unleaded.
                    • 96zjlimited
                      • 2092
                      Check voltage at the idm, should be about 40? Volts I think? A decent scan tool will do it
                      • Chrm97PI
                        268ponies with more onthe way
                        • 3413
                        i would say cam sensor, if you can data log, monitor sync, ficm sync, ficm M voltage, ICP.
                        odds are your sync or ficm sync is dropping out. FICM Mv. should be greater than 44v, ICP must be a minimum of 500psi
                        oh and cam sensors on 6.0's suck inless your a contortionist. its up on the block behind the power steering pump
                        other posibility is of a leaking ICP sensor causing a short which is back on the high pressure pump
                        • Nichols92
                          Heavy Hitter
                          • Apr 2009
                          • 2792
                          I'd believe you
                          • 98RioRedGT
                            • 1966
                            ficm or sticking egr valve. i haven't seen any 6.0's with cam sensor problems.
                            -1969 Mach1 428 SCJ project
                            • 1moretoy
                              EAT SLEEP FISH
                              • 27018
                              ficm
