Tall Valve Covers 5.0 EFI
  • robl110
    • Oct 2008
    • 343
    Anyone have recommendations for tall valve covers that work with 5.0 efi. I will be installing the Edelbrock Performer RPM II intake with spacer at the same time. Looking for some that won't take a lot of modifications and will work with aftermarket heads with larger rockers for future upgrades. Need to have the baffles in them since I am running boost and a breather. The planner looking the better. If I can get a set fast I will run them over to Cooters for wrinkle black powder to match the intake.
    I think any tall one will work for you as long as your spacer is tall enough. I just ran stock height fox valve covers made by trick flow. I dont have a spacer either. I couldnt run it without changing hoods, someting I wont sacrifice. When you go to call Jon at TNT, ask what he has or what he can get.
    • MulletMafia
      Certified
      • Oct 2009
      • 1015
      i did the edelbrock performer on my car with the half inch heat spacer and my throttle cable bracket sits right on my valve cover after i modified it a little bit. i have the ford motorsport tall covers
      • robl110
        • Oct 2008
        • 343
        Are you talking about these?
        • MulletMafia
          Certified
          • Oct 2009
          • 1015
          Originally posted by robl110 View Post
